k - omega SST turbulence model with wall functions |
January 17, 2013, 06:14 |
Hello to all,
Recently I have been reading a lot about Menter's k-omega SST turbulence model to be able to get more conscious with its usage. I found out that it has very well improved formulations for near-wall flows, when grid resolution is adequate in this region. However i couldn't get to understand the following issues: - Does this model still have improved skills over the k-epsilon model, when i have a coarse near-wall mesh? - Menter's k-omega model is said to switch between k-epsilon and k-omega, in free-stream region and near-wall region, respectively. So, if i have for example a y+>30 mesh near-wall, does this switching take place? If it does, how? Because i think wall functions already handle closest cells near wall. - I guess the SST formulation isn't activated in coarse near-wall meshes, is it true? Thanks in advance. Kenan |
k-omega sst model |
turn off wall functions in Transition SST model? | johnp | FLUENT | 11 | May 26, 2020 13:57 |
Fluent :- turbulence Model | prince_pahariaa | FLUENT | 9 | May 20, 2016 03:41 |
k-omega SST cylinder with no wall Functions | owayz | OpenFOAM Running, Solving & CFD | 10 | July 31, 2012 16:57 |
Use of k omega turbulence model | john_w | OpenFOAM Running, Solving & CFD | 2 | September 22, 2009 05:15 |
3-D turbulence model with wall function | Henry | Main CFD Forum | 7 | May 19, 2006 10:40 |
