February 26, 2013, 12:19 |
Radiation modeling
Michael P. Owen
Rep Power: 17 |
Greetings. I have a project that involves modeling a Waelz process kiln. In brief, a bed of feed material moves it's way down the kiln releasing zinc vapor and CO. Both oxidize in a counter-flowing draft air stream to form CO2 and zinc oxide dust. Temperatures range from approximately 300 K at the draft air inlet up to the south side of 2000 K. For now the ZnO dust is being left as a component ideal gas in the reacting mixture, although later we will be moving to a multiphase reaction and modeling it as a dispersed particulate. The local mass fractions of Zn, CO, ZnO, and CO2 can be quite high (~50%, 40%, 20%, and 20% max). The feed material comes in with some moisture content, but dries quickly near the draft air outlet, such that the only moisture in most of the flow comes in with the draft air.
I am hoping that someone with more experience modeling high temperature flows, e.g. combustion, can provide some guidance on selecting an appropriate radiation modeling approach and absorption and scattering information. The relevant band is about 1 to 10 micrometers. Any thoughts would be greatly appreciated. |
February 26, 2013, 16:53 |
Rep Power: 143 |
CFX has some radiation models suitable for situations where the rays do not penetrate very far. I suspect that will be the case here with such high loads of solid particles. Are you using CFX? Have you looked at the radiation models available with CFX?
Radiation modeling | cloudnqh | FLUENT | 9 | July 19, 2018 17:14 |
Modeling both radiation and convection on surfaces - Ansys Transient Thermal R13 | s.mishra | ANSYS | 0 | March 31, 2012 04:12 |
Modeling Thermal Radiation | Kaushik Saha | FLUENT | 0 | September 17, 2008 19:12 |
Question about Radiation Modeling | Zhengcai Ye | FLUENT | 0 | October 12, 2004 18:44 |
Benchmark example for 3D radiation modeling! | Klaus-Peter Helbig | Main CFD Forum | 3 | October 25, 1999 02:40 |
