a little smaller Strouhal number
Old   May 16, 2013, 07:07
Default a little smaller Strouhal number
kkpal is on a distinguished road
hi everyone!
I am simulating flow around cylinder at Re=100. But no matter how I tried, the St number I am obtaining remains 1.4, for which an accurater one is 1.6.
does someone have any suggestion on how to get the accurate St number?
my case setup is like this:
D=1, U=1, nu=0.01, no turbulence model.
any help is appreciated!
kkpal is offline   Reply With Quote
Old   May 16, 2013, 07:18
RodriguezFatz's Avatar
Philipp
RodriguezFatz will become famous soon enough
Hi, what size is your domain, i.e. how many D upstream and downstream of the cylinder?
The skeleton ran out of shampoo in the shower.
RodriguezFatz is offline   Reply With Quote
Old   May 16, 2013, 07:33
Thank you for your quick reply.
upstream, top and bottom distance are all 20D, downstream 40D. I've tried refine my mesh, but the result is not satisfactory.
Old   May 16, 2013, 07:36
Philipp
Can you also tell us the density and the viscosity?
Old   May 16, 2013, 08:00
the density rho is set to be 1, and the kinematic viscosity is 0.01. With velocity=1 and Diameter=1, that makes Re =100.
the software I'm using is OpenFoam.
I get quite good result in terms of drag and lift coefficients, but for St, it's always smaller.
Old   May 16, 2013, 08:40
Philipp
How many time steps per cycle do you have? How much do the residuals go down each time step? How large is the domain perpendicular to the flow?
Maybe you want to have a look at this thread:
http://www.cfd-online.com/Forums/mai...r-re-40-a.html
Old   May 16, 2013, 09:40
My timestep is decided by the Courant number=0.5, in my case deltaT is around 0.01s. Suppose St=0.2, vortex shedding period is around 5s, so there are 500 timesteps for each shedding cycle.
" the domain perpendicular to the flow", do you mean the height of the Z axis? it is 0.1D, as D=1, it should be 0.1. My case is 2d so I think it does not matter.
As for the residuals, in OpenFoam different variables have different residuals, here is my setting for residuals in openfoam
solvers
    p
        solver          GAMG;
        tolerance       1e-06;
        relTol          0.01;
        smoother        GaussSeidel;
        cacheAgglomeration true;
        nCellsInCoarsestLevel 10;
        agglomerator    faceAreaPair;
        mergeLevels     1;
    pFinal
        solver          GAMG;
        tolerance       1e-06;
        relTol          0;
        mergeLevels     1;
    "(U|k|epsilon)"
        solver          PBiCG;
        preconditioner  DILU;
        tolerance       1e-05;
        relTol          0.1;
    "(U|k|epsilon)Final"
        $U;
        tolerance       1e-05;
        relTol          0;
I will have a look at that post first.
thanks for your help! phillipp
you are very kind!
Old   May 16, 2013, 09:43
Philipp
500 time steps is really huge... 50 should be by far enough as far as I know.
No, sorry I don't mean the hight of the cylinder but the "other" dimension of your 2d flow domain. But sorry I just saw that you already wrote "2*20D" in your previous post...
What about your grid? Can you post a picture of it? How many cells do you have?
Old   May 16, 2013, 09:49
here is a picture of the domain and mesh.
mesh information:
70900 elements
47488 vertices
by the way, do you have a similar mesh file that yields good St number? if you have, could you please send to me so i can test in my own case?
Old   May 16, 2013, 09:55
Philipp
No, unfortunately not, and I am currently running computationally expesive simulations, so I can't just give it a try...
Maybe tomorrow.
Btw: You mean St=0.16 and not 1.6 in your first post, right?
Old   May 16, 2013, 10:06
yes, that's what i mean. my St number is 1.4, which I think is too low. actually according to the references i found, St should be around 1.65 when Re is 100.
If you have time, please help me with that mesh file, this problem has been haunting me for a week!
It's 23pm in japan now and I need to go home.
i will let you know if i have any progress.
thank you again for you kind help!
have a nice evening!
Old   May 16, 2013, 12:01
Default Mesh is available
  #12
Far
Sijal
Far has a spectacular aura aboutFar has a spectacular aura about
Send a message via Skype™ to Far
mesh information:
70900 elements
47488 vertices
Mesh can be downloaded from links given in thread
Possible issues are:
1. Mesh
2. Convergence (reduce convergence level to 1e-19). Laminar flow should be converged more tightly.
3. Method of determining the strouhal number including the manipulation of transient data
4. Time step size
Are you talking about Cd ?
Few results from Ansys documentation for similar case:
Far is offline   Reply With Quote
Old   May 16, 2013, 13:23
cfdnewbie
cfdnewbie is on a distinguished road
What type of BCs are you applying on the free surfaces? What quantity do you use to measur Str? How do you determine the frequency? By FFT or by eye? Have you validated your code for other cases?
cfdnewbie is offline   Reply With Quote
Old   May 17, 2013, 01:48
For Far:
yes, I made a mistake in the previous post.
My St is 0.14 while the accurate one should be 0.16.
I'm trying lowering the convergence level to 1e-12 because lowering to 1e-18 really takes a lot of time. I will post the result when it is finished.
As for the two pictures you posted, I think in my case, both timestep per cycle(in my case 500 timesteps per cycle) and number of nodes(in my case 47488 vertices) are fine enough.
For cfdnewbie:
inlet
U: fixed value (1 0 0)
p: zeroGradient
outlet
U: zeroGradient
p: fixed value 0
cylinderwall
U: fixed value (0 0 0)
p: zeroGradient
sidewall
U: slip
p: slip
frontandback
U,p: empty (indicate 2D)
I used the data from Cl(lift force coefficients) to calculate the Str. Both Fourier transform and direct observe from the Cl plot diagram yield the same result.
since I am using OpenFoam, I suppose the code itself should be correct, the problem is I have to find the appropriate mesh and settings.
Actually what I am trying to solve is a validation case, after this I will perform some simulations with higher Re and more sophisticated geometry.
Old   May 17, 2013, 01:54
Philipp
You should have a look at the boundary layer at your cylinder and see how many grid points you use to resolve it.
Old   May 17, 2013, 01:58
The result of convergence level 1e-12 has come out. St remains 1.44.
It seems the problem does not come from convergence level.
the numerical schemes I'm using is like this:
ddtSchemes
    default         Euler;
gradSchemes
    default         Gauss linear;
    grad(p)         Gauss linear;
    grad(U)         Gauss linear;
divSchemes
    default         none;
    div(phi,U)      Gauss limitedLinearV 0.5;
    div(phi,k)      Gauss limitedLinear 0.5;
    div(phi,epsilon) Gauss limitedLinear 0.5;
    div(phi,R)      Gauss limitedLinear 0.5;
    div(R)          Gauss linear;
    div(phi,nuTilda) Gauss limitedLinear 0.5;
    div((nuEff*dev(T(grad(U))))) Gauss cubic;
laplacianSchemes
    default         none;
    laplacian(nuEff,U) Gauss linear corrected;
    laplacian((1|A(U)),p) Gauss linear corrected;
    laplacian(DkEff,k) Gauss linear corrected;
    laplacian(DepsilonEff,epsilon) Gauss linear corrected;
    laplacian(DREff,R) Gauss linear corrected;
    laplacian(DnuTildaEff,nuTilda) Gauss linear corrected;
interpolationSchemes
    default         linear;
    interpolate(U)  linear;
snGradSchemes
    default         corrected;
fluxRequired
    default         no;
    p               ;
Do you think I need to change one thing or two?
Old   May 17, 2013, 03:40
Far
Sijal
You can find mesh here : http://www.cfd-online.com/Forums/ansys-meshing/96191-meshing-gambit-analysis-flow-past-cylinders.html.
Try it and see whether you get better results or not?
  1. How many cycles you are considering for finding St no? .
  2. did you include initial transients?
  3. After how many cycles you collected data?
  4. What time step you are using and how did you calculate it?
  5. I would use maximum 50-60 time steps per cycle and at least 3-4 cycles when initial transient are vanished!!!
PS : openfoam related question can be best answered in openfoam forum
Old   May 17, 2013, 05:59
Philipp: here is a zoom in look of the mesh near the cylinder. I've tried dividing the perimeter of the cylinder into 128 and 200, but with no luck.
Sijal: here is a picuture of the Cl plot.
For FFT, I cut the former part of this plot and used the steady one do calculate frequency. for example, in this case I used 160s~240s to do FFT. I also calculated frequency by manually observe the time difference between two peaks in the steady part.
I decide timestep by courant number<0.5, and usually timestep is 0.01 or smaller, depending on the smallest grid size and mesh fineness. One disadvangtage of this is that my timestep is not even. When doing FFT, I used EXCEL to first get a time-uniformly distributed data by linear interpolation, then perform FFT in matlab using this data with a constant timestep.
besides, the mesh you provided seems problematic when converting to openfoam mesh, anyway I am working to solve this.
Old   May 17, 2013, 06:14
Philipp
Sorry, I mean the actual flow field (e.g. velocity), not the mesh.
You should have a look at the spatial sampling of the velocity, perpendicular to the wall. You need to ensure, that the boundary sheath grid spacing is fine enough to capture the relevant effects...
Old   May 17, 2013, 20:30
dear all
my problem of getting smaller Str number is now solved.
It turns out that my mesh is Ok, the problem lies in the under-relaxation factor I employed in this unsteady cases. It is found out when using under relaxation in unsteady cases, the simulation won't be time-accurate, so in my case Drag and lift coefficients are OK but vortex shedding frequency becomes bad. I removed the relaxation factors in my settings and then the right results came out.
anyway, I really appreciate your help in this thread!
ERROR #001100279 has occurred in subroutine ErrAction. smnaryal CFX 11 December 20, 2017 16:32
compressible flow in turbocharger riesotto OpenFOAM 50 May 26, 2014 01:47
error in parallel run immortality OpenFOAM Running, Solving & CFD 7 January 1, 2013 13:35
Problem with decomposePar tool vinz OpenFOAM Pre-Processing 18 January 26, 2011 02:17
strouhal number for ellipse ek Main CFD Forum 2 December 24, 2008 23:15
