Turbulence modelling validation : Orifice flow
Old   July 26, 2006, 05:00
Default Turbulence modelling validation : Orifice flow
Joe
I've been searching hard for a good paper / vaidation database entry relating to the flow and turbulence fields within and downstream of a simple orifice flow meter aka "plate with a circular hole in it".
Idealy I'm looking for:
-LDA measurements (both within and downstream of the orifice) -Incompressible fluid with ReD = O(10000) -Simple circular orifice plate mounted inside straight circular tube
I've searched high and low through google.scholar abstracts etc. This sort of dataset seems likely to be a well used test case for validation of CFD turbulence modelling, and yet I cant find a decent set of experimental data!
Could anyone recommned a particular paper / experimental data set?
Thanks!
Old   July 26, 2006, 08:18
Default Re: Turbulence modelling validation : Orifice flow
Jim_Park
You should contact Professor Gerry Morrison Texas A&M University (www.tamu.edu ?).
He and his students conducted exhaustive studies of orifice flows in the early 90's. You could also do your literature search keying on Morrison.
Good Luck!
Old   July 26, 2006, 16:41
Joe
Much obliged.
I actually already had one of his excellent papers but the Ma number was too high (> 0.3). However, following your advice I downloaded and rummaged through his CV and found a nearly identical paper at a much lower Re number.
Thanks for the help! May be convergence fairy rain blessings upon you...
Turbulence postprocessing Mohsin FLUENT 2 October 3, 2016 14:18
modelling blood flow in arteries with starcd sara Siemens 5 April 10, 2007 09:17
Turbulence in a pipe flow JM Main CFD Forum 4 December 21, 2006 04:04
Orifice Flow Prateep Chatterjee FLUENT 4 February 23, 2001 14:59
