Turbulence modelling validation : Orifice flow |
July 26, 2006, 05:00 |
I've been searching hard for a good paper / vaidation database entry relating to the flow and turbulence fields within and downstream of a simple orifice flow meter aka "plate with a circular hole in it".
Idealy I'm looking for: -LDA measurements (both within and downstream of the orifice) -Incompressible fluid with ReD = O(10000) -Simple circular orifice plate mounted inside straight circular tube I've searched high and low through google.scholar abstracts etc. This sort of dataset seems likely to be a well used test case for validation of CFD turbulence modelling, and yet I cant find a decent set of experimental data! Could anyone recommned a particular paper / experimental data set? Thanks! |
July 26, 2006, 08:18 |
Re: Turbulence modelling validation : Orifice flow
You should contact Professor Gerry Morrison Texas A&M University (www.tamu.edu ?).
He and his students conducted exhaustive studies of orifice flows in the early 90's. You could also do your literature search keying on Morrison. Good Luck! |
July 26, 2006, 16:41 |
Much obliged.
I actually already had one of his excellent papers but the Ma number was too high (> 0.3). However, following your advice I downloaded and rummaged through his CV and found a nearly identical paper at a much lower Re number. Thanks for the help! May be convergence fairy rain blessings upon you... |
Turbulence postprocessing | Mohsin | FLUENT | 2 | October 3, 2016 14:18 |
modelling blood flow in arteries with starcd | sara | Siemens | 5 | April 10, 2007 09:17 |
Turbulence in a pipe flow | JM | Main CFD Forum | 4 | December 21, 2006 04:04 |
Orifice Flow | Prateep Chatterjee | FLUENT | 4 | February 23, 2001 14:59 |
