August 30, 2006, 03:14 |
no wind greenhouse ventilation
Hi all,
I am simulating buoyancy driven airflow in a naturally ventilated greenhouse under no wind conditions. I have the building placed in box type domain with pressure type outlets at the boundaries (except the floor), which represent the ambient external environment. I have specified a constant static pressure at these outlets, which is 0 relative to a reference pressure of 101325 pa. However, I cannot get convergence from this set-up when I have heat sources in the building no matter how much I under-relax the calculations. Can anyone give any suggestions. Is the constant pressure all around the building resulting in an unstable situation. If so, should I give a pressure profile at these boundaries? Thanks in advance |
FSI - Wind Turbine | AUN | CFX | 13 | August 29, 2012 16:44 |
Virtual Wind Tunnel in FLUENT | ND | FLUENT | 0 | April 7, 2006 07:43 |
wind engineering problem | justin | Main CFD Forum | 0 | February 20, 2006 19:23 |
Wind tunnel modeling | Pandu | CFX | 3 | May 19, 2003 21:49 |
Atmospheric Wind Profile - Inlet Subroutine | Roger | Siemens | 3 | December 12, 2002 10:00 |
