turbulence model in internal combustion engine
Old   December 4, 2006, 18:01
Default turbulence model in internal combustion engine
George
Hello, I have written a source code simulating 3D flow in an internal combustion engine (curvilinear, unsteady, compressible, turbulent). Until now I have incorporated the standard k-epsilon turbulence model and the RNG k-epsilon. Except from LES and RSM, which other turbulence model is the better for in-cylinder simulation? What about non-linear k-epsilon models?
When I use the RNG model, the code converges much more slowly than with the standard k-e model (50% more iterations). Is this expected?
Thank you in advance
gamma-ReTheta turbulence model for predicting transitional flows FelixL OpenFOAM Programming & Development 123 August 30, 2022 11:50
Water subcooled boiling Attesz CFX 7 January 5, 2013 03:32
Advice on turbulence model for complex internal flow JPBodner Main CFD Forum 1 September 3, 2011 03:07
LES and combustion model Margherita Cadorin CFX 0 October 29, 2008 05:24
numerical simulation of internal combustion engine hamed FLUENT 0 October 19, 2005 03:03
