critical Reynolds number
Old   December 4, 2006, 04:31
Default critical Reynolds number
jag
what is the criticl Reynolds number when water flows through pipe? what is the critical Reynolds number when air flows through pipe? thanks
Old   December 4, 2006, 09:32
Default Re: critical Reynolds number
ag
The critical Re for pipe flow is usually taken as ~ 2300, assuming you are referring to transition to turbulence. This Re is based on pipe diameter and does not depend on the type of fluid.
Old   December 4, 2006, 11:35
jag
thanks for ur reply but Reynolds number = ud/kienmatic viscosity.. so Re depends on kinematic viscosity also..... this is my doubt..
Old   December 4, 2006, 12:58
ag
Yes, it does - so use the correct kinematic viscosity for the appropriate fluid. The critical Re is still ~2300.
Old   December 4, 2006, 22:26
jag
thank u......
reynolds number averaging?? qrie Main CFD Forum 0 June 26, 2010 03:46
Low Reynolds Number k-epsilon formulation CFX 10.0 Chris CFX 4 December 7, 2009 23:51
Reynolds Number Matt CFX 0 February 25, 2009 05:40
Critical Reynolds Number Dipankar Chatterjee Main CFD Forum 0 September 4, 2002 10:01
High Reynolds Number Incompressible Flow Nick Lavery Main CFD Forum 3 February 19, 2002 15:47
