December 23, 2013, 06:26 |
modelling pump-sump using VOF
Virendrasingh Pawar
Rep Power: 12 |
hello,
i am using vof method to model standard pump model ( v c patel et al. 1998). water flows from inlet into the sump and then through suction pipe. i have defined a fixed volume of air over water domain. for turbulence i am using ke-std with scalable wall functions. after convergence i found that streamlines form the water surface are entering into air domain!! (note: single phase results for same problem were fairly accurate) please help me with suggestions and comments. |
Interfoam - sump pump modelling | cfdan | OpenFOAM Running, Solving & CFD | 17 | October 12, 2021 12:04 |
Low temperatures modelling heat pump with source terms | stahl | FLUENT | 0 | November 26, 2010 16:43 |
pump meshing inside the sump | ashwin | FLUENT | 0 | March 16, 2007 06:57 |
Pump in a sump meshing | Ashwin C Punjabi | FLUENT | 0 | March 12, 2007 23:52 |
Modelling flow around a ship's hull using vof | Manoj Kumar | FLUENT | 0 | February 26, 2005 16:22 |
