Boundary Conditions for a flow in pipes
Like Tree5Likes
  • 3 Post By pudasainee
  • 1 Post By vishnu_240
Old   March 22, 2014, 11:39
Default Boundary Conditions for a flow in pipes
Masoud
masoudmohammadian is on a distinguished road
Hi dear friends
What is boundary conditions(inlet and outlet) that we should use in a compressible flow in a pipe and what is your reference? Kindly flow is subsonic.
regards
Last edited by masoudmohammadian; March 23, 2014 at 14:47. Reason: I made mistake because the flow is compressible not incompressible
masoudmohammadian is offline   Reply With Quote
Old   March 23, 2014, 07:34
sanam pudasaini
pudasainee is on a distinguished road
Originally Posted by masoudmohammadian View Post
Hi dear friends
What is boundary conditions(inlet and outlet) that we should use in a incompressible flow in a pipe and what is your reference? Kindly flow is subsonic.
regards
You can use either mass flow rate or velocity as inlet boundary condition and relative pressure as outlet boundary condition. But first set your reference pressure in order to use relative pressure.. Hope it helps
pudasainee is offline   Reply With Quote
Old   March 23, 2014, 07:57
Vishnu C
vishnu_240 is on a distinguished road
For inlet give velocity inlet condition and for outlet pressure outlet
masoudmohammadian likes this.
vishnu_240 is offline   Reply With Quote
Old   March 23, 2014, 09:09
Masoud
Hi dear friend
Is it correct to use velocity when density is not constant? what is your reference of your answer?
Old   March 23, 2014, 09:11
Masoud
thanks a lot my friend. I need the reference for your reply such as book, paper,...
Old   March 23, 2014, 10:20
Vishnu C
Hi dear friend
You are asking for incompressible right? if it so then density is constant in that case.
For reference you can read boundary condition section in Fluent manual.
Old   March 23, 2014, 14:46
Masoud
Thanks my dear friend
Sorry I made mistake because my flow is compressible
regards
Old   March 24, 2014, 00:12
som87 is on a distinguished road
Just a correction, for incompressible flow, density is not constant (atleast, not always).
Our (mu/rho) should be constant.
Best wishes,
Somdeb Bandopadhyay
som87 is offline   Reply With Quote
Old   March 24, 2014, 01:15
Masoud
hi dear friend
I didn't get your answer
regards
Old   March 24, 2014, 01:27
What I meant to say is:
When you model incompressible flow, density is not always a constant variable. Its the kinematic viscosity(=dynamic viscosity/density) which is constant. For Low Reynolds number, flow most cases, the density'll not vary much.However, when you go to the moderate Re regime, most likely your density'll vary (depending of the fluid property though). So, as long as you keep kinematic viscosity constant, you are in "safe zone". Whereas keeping a constant density may lead to error.
that's all
Best wishes,
Somdeb Bandopadhyay
Old   March 24, 2014, 01:54
Masoud
but you know, my flow is compressible with Ma No. about 0.8
Old   March 24, 2014, 02:12
I was referring to the other post actually, where it was stated that incompressible flow=constant density..that's all(that's why i used "just a correction" phrase)
Best wishes,
Somdeb Bandopadhyay
Old   March 24, 2014, 02:17
Masoud
thanks a lot dude and sorry for any inconvenience
Old   March 24, 2014, 12:54
Ramesh K
RameshK is on a distinguished road
Send a message via Yahoo to RameshK
For Compressible flow through a pipe you can give Total Pressure at inlet and static pressure at outlet and from the stagnation static relations we can estimate the flow Mach number or the other way around if you want a particular Mach Number then calculate the relations accordingly with atmospheric pressure as reference.
RameshK is offline   Reply With Quote
Old   March 24, 2014, 22:13
Vishnu C
But numerically when we solve incompressible flow equation density term will be treated as constant and removed from momentum equations so i told him in terms of CFD(since he is working in it), but when comes to flow physics what u told is correct.
Old   March 24, 2014, 22:18
To add to my point:-
http://www.sciencedirect.com/science...21999108006748
Best wishes,
Somdeb Bandopadhyay
Old   March 25, 2014, 01:45
Vishnu C
OK, i don't think all solvers use this.
Radiation interface hinca CFX 15 January 26, 2014 17:11
Boundary conditions low Mach number flow lost.identity Main CFD Forum 0 November 28, 2010 04:44
boundary conditions for boundary layer flow A. Al-zoubi CFX 0 November 3, 2007 07:11
Internal flow simulation boundary conditions Kishore FLUENT 1 July 10, 2007 11:42
Please help with flow around car modelling! Tudor Miron CFX 17 March 19, 2004 19:23
