[Help!] impeller torque calculation: pressure and viscous moments
Old   October 21, 2013, 06:52
Default [Help!] impeller torque calculation: pressure and viscous moments
ghost82's Avatar
Rick
ghost82 will become famous soon enough
Hi all!
I simulated a vessel+impeller with multiple reference frame and I want to calculate the power needed to drive the impeller: as I know the power P is:
P [Watt]=2*pigreco*N*Torque
N=revolution per seconds (12 rpm)
Torque in N*m
Impeller axis rotation is Z and the vessel is centered in X,Y; the domain is in +Z.
Impeller rotates counterclockwise.
Rotating frame is all the cylinder zone, which rotates at 12 rpm, because impeller 007/impeller 007-shadow are very closed to the wall. Bottom conical zone is stationary zone.
Vessel walls have absolute 0 rotational velocity.
Impeller/impeller 007/impeller 007-shadow have relative velocity to adjacent fluid zone of 0.
If I calculate the pressure and viscous moments (moment center: 0,0,0 moment axis 0,0,1) I have:
Impeller zone (all in N*m)
Pressure: -225
Viscous: +103
Total: -122
Impeller 007 zone (all in N*m)
Pressure: -109
Viscous: -8
Total: -117
Impeller 007-shadow zone (all in N*m)
Pressure: -107
Viscous: -8
Total: -115
So total moment is: -354
and P should be:
P=abs(total moment)*N*2*pigreco=354*12/60*2*pigreco=445 W
Is it right?
What I don't understand is why in the impeller zone viscous moment has opposite sign in respect to pressure moment.
Can anybody explain to me please?
I'm attaching some pictures.
Thank you
Daniele
ghost82 is offline   Reply With Quote
Old   March 27, 2014, 02:37
Pekka Pasanen
zordiack is on a distinguished road
Did you ever figure this out? I'm having the same problem with my turbomachinery case, the pressure moment seems to be in the right direction but the viscous moment has opposite sign, which doesn't make any sense to me.
zordiack is offline   Reply With Quote
CFD-Post: Pressure and Viscous Drag on Isosurface Shirock CFX 4 June 4, 2012 01:02
how does Fluent calculate the pressure and viscous force ? e30.lsb FLUENT 7 June 27, 2011 21:31
how does Fluent calculate the pressure and viscous force vector? Ralf Schmidt FLUENT 2 May 17, 2010 15:49
what the result is negatif pressure at inlet chong chee nan FLUENT 0 December 29, 2001 05:13
How to obtain correct viscous pressure drag using CFX? Ketut Utama Main CFD Forum 1 January 25, 1999 05:05
