Is it important to include hydrostatic pressure? |
May 10, 2007, 09:48 |
I need a confirmation on something that bothering me. I am modeling a body under the water (not interested in the free surface). Is it important to include hydrostatic pressure?. Obviously i need it to get the correct buoyancy force, but in my mind it should not affect the flow. Am i right? (constant pressure gradient should cross out). Regards, N |
May 14, 2007, 00:23 |
Re: Is it important to include hydrostatic pressur
You can see the difference between w/ hydrostatic pressure and w/o hydrostatic pressure. If there is no big difference, you can either set or not. And in case of inviscid flow, the hydrostatic pressure(gravitational effect) is usually ignored but in viscous flow, one need to consider it.
May 14, 2007, 11:36 |
how important is it in the study of something like a submarine?
Regards, Nigelo |
UDF to define or adjust pressure??? | engahmed | FLUENT | 0 | July 6, 2010 17:19 |
OpenFoam install script Error during paraFoam installation | SePe | OpenFOAM Installation | 10 | June 19, 2010 15:15 |
single phase hydrostatic pressure problem | erkan | FLUENT | 1 | March 1, 2010 12:29 |
Calculate forces without hydrostatic pressure | geir_oye | FLUENT | 4 | November 12, 2009 09:12 |
Consideration of Hydrostatic Pressure | Liwau | CFX | 1 | March 26, 2004 00:47 |
