upwind method
Old   August 5, 2008, 06:18
Default upwind method
Lee
Am using a first-order upwind method for solving a hyperbolic system. Am getting lots of oscillations with fine mesh, things with coarse mesh are fine, i.e. the solution changes and the oscillations appear after increasing the number of cells with space.
Is it possible for upwind methods to be very much oscillatory?
What is the best first-order upwind method to use?
Old   August 5, 2008, 06:59
Default Re: upwind method
Ferreira
Hi Lee,
I sugest you using the ADBQUICKEST scheme. See International Journal for Numerical Methods in Fluids, Article in Press by Ferreira, V.G. et. al. 2008.
Good Luck Ferreira
Old   August 6, 2008, 00:11
ztdep
what is the difference between the quick scheme
Old   August 6, 2008, 04:36
Default upwind methods and stationary discontinuities
Lee
I should write my question in a different way, in hope of a reply!
I have one wave only a stationary discontinuity. I known that stationary discontinuities have the largest dissipation leading to spreading of the wave as time increases, please correct me if am wrong.
No problems with time for me. If I increase the number of cells, fine mesh, I find that a huge dissipation leading to damage of the wave(s)- at the beginning and at the end of the contact wave.
Is this possible with upwind first order schemes. Does it mean that the system losses his hyperbolicity ?
Old   August 7, 2008, 14:00
Ferreira
... it is bounded ...
Old   August 10, 2008, 03:35
Default Re: upwind methods and stationary discontinuities
Anishtain4
when you solve a system it retain its mathematical characters, if it is a hyperbolic then it remains so. what is the method you are using? are you using a FV or FE method if FV which method? I used a upwind in a artificial compressibility and it came out to be oscillation in pressure field and that is because you should use central for any term that is related to pressure.
Old   August 10, 2008, 05:46
Lee
The system is hyperbolic for incompressible liquid-liquid two-phase flow. Have used a very simple upwind FV. As I said I have a stationary discontinuity i.e. one contact wave corresponding to one eigenvalue which is a linearly degenerate, and two injected discontinuities these are just point source terms. So sharp discontinuities will appear. The numerical solutions are mesh (grid) dependent. Problems starts with fine mesh. Is it because of the linearly degenerate? Or the mathematical model or the point source terms effect the hyperbolicity of the model?
2nd order upwind vs 2nd order upwind!!! Far Main CFD Forum 7 March 14, 2013 12:29
[Gmsh] discretizer - gmshToFoam Andyjoe OpenFOAM Meshing & Mesh Conversion 13 March 14, 2012 04:35
Second order upwind is not UPwind!!! Far CFX 9 May 31, 2011 08:21
2nd order upwind scheme (Fluent and CFX) Far FLUENT 0 May 22, 2011 01:50
Code for most powerfull FDV Method D.S.Nasan Main CFD Forum 6 September 4, 2008 02:08
