Gambit installation under linux
Old   November 28, 2008, 07:43
Default Gambit installation under linux
Alex
I'm trying to get gambit working under linux but get the following error:
LANG en_US.UTF-8 changed temporarily to en_US for gambit use. Starting /usr/Fluent.Inc/gambit2.4.6/lnamd64/gambit ... /usr/Fluent.Inc/gambit2.4.6/lnamd64/gambit: error while loading shared libraries: libXm.so.3: cannot open shared object file: No such file or directory
A quick look at the FAQ's on Fluent's site mentions something about needing to install openmotif. However, "rpm -qa | grep openmotif" yields;
openmotif-demos-2.3.1-1 openmotif-devel-2.3.1-1 openmotif-2.3.1-1
so I think thats installed already.
The FAQ's also say that the directory /usr/X11R6/lib64/ should have the file libXm.so.3 in it. However "ls /usr/X11R6/lib64/" yields;
modules
only. where do I get the required file from. I'm using fedora 8 by the way.
Thanks very much in advance for any help.
Alex
Old   December 4, 2008, 01:32
Default Re: Gambit installation under linux
Harish
Sometimes the default location for installation of certain files are changed on different linux distros. Did you search your system for existence of the file libXm.so.3 . If you have it somewhere else make sure its executable and create a link in the required directory to point to that file. Hope this helps.
OpenFOAM 1.7 installation on Redhat linux maxims OpenFOAM Installation 2 November 30, 2012 04:29
Dual Boot Windows and Linux and Go Open Source andyj Main CFD Forum 2 October 21, 2010 16:49
Gambit installation problem Panos FLUENT 4 March 5, 2009 22:44
Fluent and gambit installation into Linux Rashid FLUENT 0 January 17, 2008 01:43
OpenFOAM installation problem on Linux 32bit kumar OpenFOAM Installation 0 April 27, 2007 05:41
