udf on parallel fluent
Old   December 12, 2008, 07:45
Default udf on parallel fluent
stud
hi, when i run parallel fluent and execute my udf I have no problem but I have no result. this is my udf.. I don't find the problem. DEFINE_ON_DEMAND(asus) {
#if !RP_HOST Domain *d = Get_Domain(1); int ID=18; cell_t c; face_t f; #endif Thread *t=Lookup_Thread(d,ID); /* Thread *tt=Lookup_Thread(d, ID);*/ int i,ntot; #if PARALLEL int pe; #endif
real x[ND_ND]; #if !RP_NODE FILE *fp; fp=fopen("temperature.dat","w");
#endif
zeta= z0+delta/2.; i=ntot=0;
zeta= z0+delta/2.; i=ntot=0; #if RP_NODE do {
/*thread_loop_c (t,d) {*/
begin_c_loop_int (c,t)
C_CENTROID(x,c,t);
if ((x[2]<(zeta+toll)) && (x[2]>(zeta-toll)))
t = C_T(c,t);
u = C_W(c,t);
sum_t += C_VOLUME(c,t)*C_R(c,t)*teta*ustar;
sum_u += C_VOLUME(c,t)*C_R(c,t)*ustar;
end_c_loop_int (c,t)
tetab[i] =sum_t/sum_u ;
zeta +=delta;
ntot=i;
i++; } while(zeta<zout); #endif
} #if !RP_NODE do {
fprintf(fp,"%g %g\n",zeta,tetab[i]);
zeta +=delta; ntot=i; i++; }while (zeta<zout); fclose(fp); #endif
} can you help me?
Fluent UDF on parallel computing Andrea Fluent UDF and Scheme Programming 22 August 12, 2015 07:44
Fluent parallel license problem brothershuai Main CFD Forum 0 July 1, 2009 15:41
UDF of Zimont model in fluent Z Main CFD Forum 0 February 17, 2005 03:07
UDF in parallel version. yobee FLUENT 0 August 17, 2004 04:12
pressures in MDM - parallel fluent paolo FLUENT 1 April 7, 2004 00:38
