CFX- Mesh Interface
Old   October 22, 2015, 08:43
Default CFX- Mesh Interface
sandy
archeoptyrx is on a distinguished road
Hi Everyone,
I am using cfx to do some turbomachinary problems (Fluid coupling, centrifugal pump ) . I am new to this software and have some basic questions to which I couldn't find solutions anywhere.
1. When I give interface between two domains (pump and turbine). Do they have to touch each other ? or Can they have some gap between them ?
2. If I have two different assemblies in single domain and they are touching each other , should I have to give them interface in CFX? or the interfaces are meant only to different domains ?
3. I have cylindrical body and within it I have a rectangular part. This rectangular wall rotates with some RPM about Z axis. Now Can I select all four surfaces together and provide rotating wall boundary or should I have to select two walls parallel and two walls perpendicular to Z axis separately and give the rotating wall boundary condition? . Because I had problem when I tried giving rotating wall to all 4 surfaces of the rectangle. Kindly advice
It will be great if anyone clarify my doubts.
Thanks
Archep
archeoptyrx is offline   Reply With Quote
mesh interface in Fluent AvaShahrokhi FLUENT 10 December 25, 2020 07:58
[ICEM] CGNS mesh failing in CFX siw ANSYS Meshing & Geometry 5 November 23, 2017 19:07
CFX mesh & ICEM mike CFX 3 April 27, 2006 15:27
hex mesh using cfx mesh. mehul CFX 3 December 12, 2005 22:06
hex mesh using cfx mesh. mehul CFX 0 October 31, 2005 07:01
