December 13, 2007, 05:01 |
log law for wind velocity profile
Can someone help please, I'm confused...
I'm trying to create a simple spreadsheet to give wind speeds at a range of heights, from one input wind speed at a reference height. I want to do it using the log law, where u is a function of friction velocity. Friction velocity is fucntion of the wall shear stress. And the wall shear stress is a function of du/dy. I don't understand how to use this du/dy? I have 1 value for flow velocity (u) at height (y). I know du/dy is not simply u/y, but don't understand what else I can do! Would greatly appreciate any help. Thank you. |
UDF error - parabolic velocity profile - 3D turbine | Zaqie | Fluent UDF and Scheme Programming | 9 | June 25, 2016 19:08 |
Problem with assigned inlet velocity profile as a boundary condition | Ozgur_ | FLUENT | 5 | August 25, 2015 04:58 |
FSI- Pipe- uniform velocity profile inlet | Absy | Main CFD Forum | 0 | April 6, 2010 03:01 |
LES Near-Wall Velocity Profile | Alex May | FLUENT | 2 | June 12, 2008 12:36 |
What is 3D turbulent velocity profile ? | conan | FLUENT | 0 | June 9, 2008 06:44 |
