CFD for pumps
Old   August 24, 2000, 10:18
Default CFD for pumps
sameer mohrir
Hello everybody on forum
Can someone clarify why CFD analysis is required at intake side (suction side ) while designing large pumps,since small types of pump generally not required CFD analysis for design at suction side.
Old   August 24, 2000, 11:14
Default Re: CFD for pumps
Ahmed Hassaneen
What type of pump are we talking about?
Old   August 24, 2000, 12:57
John C. Chien
(1). I guess the smaller pumps cost less, so you don't want to spend a lot of time there. (2). A larger one will cost much more in casting and machining, so, there are room to do analysis and design to make sure that everything is all right. (3). A larger one sometimes is custom made. So, it is likely to do analysis. (4). CFD analysis of pumps is still relatively new, and it is rarely done in most cases.(it is still very difficult, although not impossible.)
Old   August 24, 2000, 23:14
sameer mohrir
Hello John
Thanks for clarification
sameer
Old   August 24, 2000, 23:17
sameer mohrir
Hello Ahmed
Type of pump is centrifugal
Sameer Mohrir
Old   September 20, 2000, 12:53
Zebedee Mason
I have worked on the design of internal-external gear pumps for automotive applications (Gerotors, crescents, etc). Occasionally you see someone doing a very nice and computationally expensive moving mesh simulation to check out the inlet port design.
The reason being that above a certain speed the inlet pressure will drop sufficiently to allow cavitation. This results in very noisy and inefficient operation.
Hope this helps.
Zeb
Old   September 20, 2000, 13:41
sameer mohrir
Hello Zeb
Pls . can you clarify in detail.
regards
sameer
STAR-Works : Mainstream CAD with CFD CD adapco Group Marketing Siemens 0 February 13, 2002 12:23
Where do we go from here? CFD in 2001 John C. Chien Main CFD Forum 36 January 24, 2001 21:10
ASME CFD Symposium, Atlanta, July 2001 Chris R. Kleijn Main CFD Forum 0 August 21, 2000 04:49
Since Last June John C. Chien Main CFD Forum 3 July 12, 1999 09:38
Which is better to develop in-house CFD code or to buy a available CFD package. Tareq Al-shaalan Main CFD Forum 10 June 12, 1999 23:27
