Model and Mesh generation Problems
Old   May 19, 2001, 00:58
Default Model and Mesh generation Problems
Anindya
How can I create a mesh which has cylindrical domain (fluid cells) and it will have a cubic block (solid) inside with prostar (StarCD)? I need your suggestions asap. I am trying to simulate flow through a cylindrical pipe which has a solid cubic blockage inside it. I also have access to Gridgen and ANSYS for building and meshing the model. So you can suggest me as to how to make the model using those two packages also.
Thanks a lot
Anindya
Old   May 19, 2001, 02:02
Default Re: Model and Mesh generation Problems
John C. Chien
(1). Two types of mesh can be used for a pipe, namely, a H-type and an O-type. (2). Some solvers can not handle the H-type because of the 180 degree corner. (3). So, O-type is better in this case. But the catch is it must be a multi-block O-type mesh. That is, near the pipe wall, it is O-type, and leaving the center with a four-sided H-type. (4). So, in the case of O-type, multi-block mesh, the solver must have the capability to handle it.(there will be four junction points or lines for the center mesh.)
Gambit problems Althea FLUENT 22 January 4, 2017 03:19
Mesh generation from surface model wei Siemens 2 April 24, 2009 02:33
Sector model mesh problems!! Duan J Q Siemens 4 October 7, 2007 20:05
Problems when I mesh my engine model. deisler Siemens 3 March 22, 2007 21:58
How to control Minximum mesh space? hung FLUENT 7 April 18, 2005 09:38
