Standing Cylinder
Old   June 15, 2001, 10:57
Default Standing Cylinder
Garvin Forrester
Greetings: Does anyone know of best practices for gridding a standing cylinder to resilve the boundary layer and picking up surface vortex shedding. I need spacing etc ..
Thanks.
Old   June 15, 2001, 14:28
Default Re: Standing Cylinder
Martin Nilsson
How about o-grids? Icem can do that, very good b-l's also. If the cylinder is ending in free fluid, you need o=grids on the end surfaces as well. Icem can do that too. If you don't have Icem, most commercial meshers can do this. and you can even do it with matlab if you are a bit clever. A mesh is just a bunch of coordinates, remember.
Martin
benchmark: flow over a circular cylinder goodegg Main CFD Forum 12 January 22, 2013 11:47
Incorrect Drag and Drag Coefficient for flow over a cylinder ozzythewise Main CFD Forum 8 June 13, 2012 06:24
[blockMesh] Specifying boundary faces failes in blockMesh blaise OpenFOAM Meshing & Mesh Conversion 0 May 10, 2010 03:56
rotating cylinder using sliding mesh Tim Daly FLUENT 1 November 9, 2008 23:02
Turbulent steady flow around a circular cylinder Mirek Kabacinski FLUENT 0 July 23, 2003 18:40
