SOLAVOF Sample Test Problem
Old   October 27, 2001, 00:35
Default SOLAVOF Sample Test Problem
Zi-Wei Chiou
I am rewriting the original SOLAVOF Fortran program in C++, but encouter a problem. I try to simulate the same sample test problem in the report (undular bore calculation) in page 44. All parameters are the same (NMAT=1).
QUESTION 1:
At t=0 (page 46), why U[1][7] = 0.2? Since F[1][7] is 0, why U is set for an _empty_ cell at t=0? The SETUP routine initialize U [i][j] only when F[I][J] > 0, so it's unlikely U[1][7] is set by SETUP. I've checked BC subroutine too, but it does not set U[1][7] either.
QUESTION 2:
The input FLHT (horizontal free surface height) is 1.0f, and del_y of mesh is 0.2, the fluid should occupy the bottom five rows: I=2~6.
At t=0 (page 46), before anything started, why F[1][6] is not 1 but 9.99999E-01?
BIBLIOGRAPHY:
B. D. Nichols, C. W. Hirt, and R. S. Hotchkiss, SOLA-VOF: A Solution Algorithm for Transient Fluid Flow with Multiple Free Boundaries, LANL report LA-8355, 1980.
sample utility problem And OpenFOAM Post-Processing 36 May 20, 2014 08:50
A new test harness for OpenFOAM mbeaudoin OpenFOAM Announcements from Other Sources 0 June 17, 2010 10:36
Sample utility not working properly titio OpenFOAM 2 June 9, 2010 10:45
Velocity profiles problem behind the elbow (3D problem) kabat73 FLUENT 8 May 9, 2010 04:26
setup vof test problem Fang Jin FLUENT 1 June 14, 2005 08:27
