Lid-Driven Cavity
Old   February 18, 2002, 00:06
Default Lid-Driven Cavity
Paul Safier
Can anyone give reference to a paper or book that has numerical values for the solution of the lid-driven cavity problem. I would like to compare my code with this benchmark problem.
Thank you. Paul Safier
Old   February 18, 2002, 05:54
Default Re: Lid-Driven Cavity
Paul
Please refer to the benchmark solution of Ghia & Ghia: J. Comput. Phys. V48, p387-411, 1982.
-Paul
Old   February 18, 2002, 06:57
Andrey
I have my code, and i would like to compare my results with your.
Old   February 18, 2002, 10:07
gita
Hi Paul Safier,
Ref: U. Ghia, K. N. Ghia, and C. T. Shin "High-Re Solutions for Incompressible Flow Using the Navier-Stokes Equations and a Multigrid Method", Journal Computational Physics, Vol. 48,pp: 387-411(1982). If you don't get the results then surely you need to check your code. Based on Ghia's results so many PhD degrees have been awarded! For Re=100 itself you will see corner eddies. Goodluck in getting the right results. Should be fun testing it. gita
Old   February 19, 2002, 06:20
mukhopadhyay
Paul,
you may look at : 'Handbook of Heat Transfer', edited by W J Minkowycz,E M Sparrow, G E Schneider and R H Pletcher, John Wiley & Sons (1988), [approx US$200], pages 335-338. Please do not get carried away by the numerical values only ! Compare your results with Fig 8.17 (streamline contours) for Re=10000 (uniform grid 257x257).
If you are interested in driven cavity problem, you may also refer to some discussion we had some months back (please consult the archives). what transpired was quite interesting.
2D Lid Driven Cavity Flow simulation using MATLAB josephlm Main CFD Forum 4 August 17, 2023 20:36
Lid Driven Cavity using Ghost Cell Method and in C++ illuminati5288 Main CFD Forum 0 August 12, 2011 22:05
is there any parallel code for the famous Lid Driven Cavity flow? gholamghar Main CFD Forum 0 August 1, 2010 01:55
[OpenFOAM] Paraview - Lid Driven Cavity kieranhood ParaView 0 February 13, 2010 16:28
Lid driven cavity flow KK FLUENT 1 December 16, 2009 18:10
