Computational MHD Applications?
Old   July 3, 2002, 13:13
Default Computational MHD Applications?
Joe
Hi all
I'm just wondering what kind of applications exist for Computational Magnetohydrodynamics. I can think of Solar Wind at least, but there must be others. I happened to learn that aeronautical institutes or industries are studying MHD, but don't know exactly why. When/Where do we need MHD? Can anyone give me a hint?
Thank you
Old   July 3, 2002, 15:19
Default Re: Computational MHD Applications?
frank
I think Ken Powell at the University of Michigan, also together with Van Leer do MHD. Maybe you will find some information there. The lab is called Keck laboratory http://www.engin.umich.edu/dept/aero...ities/CFD.html
Frank
Old   July 3, 2002, 16:07
xueying
I remember that Bruce A. Finlayson from chemical engineering dept at university of Washington gave us a seminar about Ferrofluid modeling. If Ferrofluid is also kind of MHD, you might check his web to see some information.
Old   July 3, 2002, 16:34
Axel Rohde
If I am not mistaken, nuclear fusion, which is still in its experimental stage, makes use of the idea of keeping the very hot plasma (which would otherwise melt the reactor walls) inside a 'magnetic bottle'. Computational MHD is used in 'designing' this magnetic bottle.
Old   July 4, 2002, 09:35
Jim Park
Perhaps 15 years ago, power generation firms in the US, including the Tennessee Valley Authority, were looking at MHD as a means of increasing the efficiency of coal-burning power plants. The idea was to generate high combustion temperatures, ionizing the combustion gases, running them through a magnetic field and tapping the power from that. As the hot plasma cooled and lost its charge, it was run through a 'conventional' boiler or gas turbine to generate more power. In addition to higher efficieny, more complete combustion and better control of polluting emmissions were promised with this scheme.
I recall that high corrosion and fouling rates made the scheme unattractive.
I think the US Department of Energy still has a lab in West Virginia (?) that is working on these ideas.
Old   July 5, 2002, 08:36
Knut
MHD is applied to optimize several mettalurgical processes, such as aluminium electrolysis, electromagnetic pumping etc.
Old   July 9, 2002, 12:18
Joe
Now I can use those key words you mentioned to search more infomation.
Thank you! Joe
CFX11 + Fortran compiler ? Mohan CFX 20 March 30, 2011 18:56
free "Computational Mechanics" noname Main CFD Forum 0 March 2, 2007 07:03
computational MHD flows, boundary conditions packer Main CFD Forum 0 March 21, 2006 03:35
Short Course: Computational Thermal Analysis Dean S. Schrage Main CFD Forum 11 September 27, 2000 17:46
liquid/solide phase change problems mehdi fteity Main CFD Forum 3 September 14, 2000 21:44
