help on silo file system
Old   May 28, 2003, 09:34
Default help on silo file system
dragson
Now for work's need, I need to know the silo grid file addressed by MeshTV and VisIt,it's struture and how to write it. thanks!
Old   May 28, 2003, 10:21
Default Re: help on silo file system
andy
go to www.google.com and type:
"meshtv silo"
Old   May 28, 2003, 10:36
dragson
thanks for your kind. I already have a copy of silo's user guide , but find it that it's too complexity, for program's seek, some difficulty in realizition it in win2000's operaton system.could yougive me some more advice!
Old   May 28, 2003, 11:23
andy
It is documented, open source and supported by LLNL (though I have not checked the latter). It compiled with no problems on my unix system. It is more for structural problems than CFD problems though.
I checked the system a while ago and the plotting of a scalar variable required 4 function calls: create database, put mesh, put variable, close database. I got this from the introduction in the silo reference manual. Meshtv read the file without a problem. Perhaps things get more complicated later?
If you have problems developing code on Windows then install FreeBSD, Solaris or Linux which are all free for PC hardware. Most CFD software will have been developed on unix-like systems.
If you are struggling with open software from LLNL then I would suggest sticking with pre-built executables. The cost of fieldview, tecplot or whatever is likely to be less than the time you lose messing around.
Old   May 29, 2003, 07:44
dragson
Thanks for your kindness,on the help of one of my good friends, he is a linux expert, seggust by him, and more work done by himself ,today we get the first result---the example supplied by the "silo user guide" writting the silo files.maybe more work need to be done,but we happy to get the result. we work on Solaris sunos.any how thank you.
CFX11 + Fortran compiler ? Mohan CFX 20 March 30, 2011 18:56
Working directory via command line Luiz CFX 4 March 6, 2011 20:02
OpenFOAM Install Script ljsh OpenFOAM Installation 82 October 12, 2009 11:47
DecomposePar links against liblamso0 with OpenMPI jens_klostermann OpenFOAM Bugs 11 June 28, 2007 17:51
error while compiling the USER Sub routine CFD user CFX 3 November 25, 2002 15:16
