Kinetic Theory
Old   June 24, 2003, 12:05
Default Kinetic Theory
Tommaso
hi
In the ideal gas model using the kinetic theory for Cp and K, which are the values to insert in degrees of freedom...........
thanks in advance payment
Old   June 30, 2003, 10:06
Default Re: Kinetic Theory
Nicola
It depends on the gas molecule you are considering.
For a mono-atomic gas 3 DoF:
Cv=3 R/2 ; Cp=3 R/2 + R
For a bi-atomic gas 5 Dof:
Cv=5 R/2 ; Cp=5 R/2 + R
For a tri-atomic gas 6 DoF(assuming the atoms are not on the same line):
Cv= 3 R ; Cp= 4 R
These formulas hold under the assumption that the vibrational energy is negligible and that the relative motion of the atoms of the molecule can be neglected (the molecule is assumed to be a solid body).
Hope it helps
Nicola
udf for cohesive forces in kinetic theory T.Hari FLUENT 1 October 6, 2014 14:41
kinetic theory in fluent leila.emamitaba FLUENT 0 October 12, 2011 03:00
Mixture model and kinetic theory Fuping Qian FLUENT 3 January 24, 2011 06:58
Kinetic Theory in Multiphase mtl Main CFD Forum 0 June 3, 2009 22:54
solid kinetic theory wan xiaotao Main CFD Forum 6 August 10, 1999 18:43
