Cd Value of a cylinder
Old   April 30, 2009, 01:22
Default Cd Value of a cylinder
Ranjith
mranji1 is on a distinguished road
I have simulated flow over a stationary cylinder using the immersed boundary method.I used feedback forcing schme with 4-point delta function.The no-slip boundary conditions are satisfying and the l2-norm error is of the order of 10e-4.but iam getting a high value of Cd.when i used a domain of 14dx7d with d=1 for Re=10 i got Cd=4.37.when i doubled the domain i got Cd=3.29.time step i used is 10e-3.Can anyone tell me what will be the problem.i computed Cd using the method prescribed by Peskin...adding all the momentum forcing values for the drag force and then using the wellknown cd formula.....
Plse give a reply......
Thankig you all.......
mranji1 is offline   Reply With Quote
Old   April 30, 2009, 01:55
Daniel Langmayr
xdanielx is on a distinguished road
have a look at
http://www.cfd-online.com/Forums/ope...-cylinder.html
hope this helps and good luck!
xdanielx is offline   Reply With Quote
3-d mesh gambit (cylinder within a cylinder) Jason ANSYS Meshing & Geometry 29 October 30, 2015 08:59
benchmark: flow over a circular cylinder goodegg Main CFD Forum 12 January 22, 2013 11:47
rotating cylinder using sliding mesh Tim Daly FLUENT 1 November 9, 2008 23:02
Turbulent steady flow around a circular cylinder Mirek Kabacinski FLUENT 0 July 23, 2003 18:40
moving cylinder blur boy Main CFD Forum 4 October 12, 2001 05:32
