Steady time step
Old   January 22, 2004, 12:18
Default Steady time step
Jim
I am trying to compute the allowable time-step at each grid point in order to satisfy the CFL condition. The problem I am solving is steady and so I can use different time-steps at each point. I realise that I need to find the max. wavespeed at each point to determine the time-step. I am using MacCormack's method and the stencil for each grid point is three points (i-1, i, i+1), so I need to consider flow conditions at all three stencil points in order to compute the allowable time-step at each grid point. However, I can't seem to be able to code this correctly. I'm using Visual C++ and have so far written:
for (i = 1; i <= no. grid points; i = i + 1)
wav = 0.0;
lambda[1] = m_old[i]/ro_old[i] - sqrt(gam*p_old[i]/ro_old[i]);
lambda[2] = m_old[i]/ro_old[i];
lambda[3] = m_old[i]/ro_old[i] + sqrt(gam*p_old[i]/ro_old[i]);
for (j = 1; j <= 3; j = j + 1)
if (fabs(lambda[j]) > wav)
wav = fabs(lambda[j]);
deltat[i] = cflno*dx/wav;
When I run my program I get a very unstable solution and I think it's due to this time-step calculation.
Any help would be greatly appreciated.
Thanks.
SLTS+rhoPisoFoam: what is rDeltaT??? nileshjrane OpenFOAM Running, Solving & CFD 4 February 25, 2013 04:13
Upgraded from Karmic Koala 9.10 to Lucid Lynx10.04.3 bookie56 OpenFOAM Installation 8 August 13, 2011 04:03
Full pipe 3D using icoFoam cyberbrain OpenFOAM 4 March 16, 2011 09:20
Differences between serial and parallel runs carsten OpenFOAM Bugs 11 September 12, 2008 11:16
false time step implementation for steady state Kushagra CFX 1 June 22, 2008 19:06
