shock capturing
Old   May 29, 2004, 13:02
Default shock capturing
Muhammad zubair
i am reading CFD by john D.anderson(chapter 10).in flow chart discussed in this chapter, i want to solve euler equations instead of complete navier stokes equations.how it can be done.what changes i have to made in computational domain and flow properties. can still shock capturing be performed.how thanking in advance Muhammad zubair
Old   May 30, 2004, 07:24
Default Re: shock capturing
cjtune
I think you should go through the example where the MacCormack scheme was set-up to simulate shock in a quasi 1-D laval nozzle (Chapter 7 was it?). As long as you are using the conservative form of the equations, shocks will be naturally 'captured' along with the rest of the solution.
Old   May 31, 2004, 01:28
jyothish
Dear asif,
Regarding ur problem in solving euler equations, you have to change the boundary conditions from no slip to slip conditions (i.e) V.n = 0. (normal component of velocity is zero.)
jyo
Zalesak ST A preliminary comparison of modern shock capturing mcaro Main CFD Forum 0 September 1, 2010 18:07
Numerical viscosity & shock capturing Dave Main CFD Forum 20 August 12, 2008 13:17
is there a new method to emulate shock capturing>? prapanj Main CFD Forum 0 July 25, 2006 01:44
Shock Capturing in a Con-Di Nozzle. Meriem Allouache Main CFD Forum 3 December 27, 2004 05:49
Shock capturing Dr B.M. Smith (Smith) OpenFOAM Running, Solving & CFD 1 December 10, 2004 05:40
