May 26, 2004, 20:41 |
flow rate in vertical tube
What would be the most appropriate inlet and outlet boundary conditions for an incompressible steady state flow in a vertical tube. The flow rate is sought as part of the solution.
I tried inlet zero refernce pressure and a free fully developed oultlet condition but with no success. Your kind response is appreciated. |
May 30, 2004, 09:08 |
Re: flow rate in vertical tube
For inlet: velocity is prescribed, pressure is extrapolated from interior, For outlet: Pressure is prescribed, velocities are extrapolated from interior. Try above BC.
May 30, 2004, 16:23 |
Versi, You Kindly responded: "For inlet: velocity is prescribed, pressure is extrapolated from interior, For outlet: Pressure is prescribed, velocities are extrapolated from interior. Try above BC."
But I thought prescibing velocity at the inlet (or exit)implies prescibing the flow rate itself for such steady state simulation. I am looking for BC's that will lead to the flow rate as an output results not as an input. What do you suggest. Thanks |
Max.allowable flow rate in a packed bed | Mamata | FLUENT | 3 | May 29, 2017 12:33 |
Mass flow rate | sepidecent | CFX | 0 | August 9, 2011 00:15 |
mass flow rate on the Iso-clip surface & interior | Sunil Gupta | FLUENT | 0 | April 22, 2008 09:29 |
mass flow rate error | Masood | FLUENT | 0 | May 22, 2005 00:32 |
Inlet and outlet flow rate | Neser | CFX | 1 | March 2, 2004 16:02 |
