July 6, 2004, 18:12 |
central, upwind, UTOPIA, staggered grids
I am looking for good reference for convection terms discretisation and stabilization methods, mean about comparison of central differences, upwind (on staggered grids). I work with incompressible, free surface flows (SIMPLE, MAC).
Hope to get some reply this time.. Best Regards, Maciej Matyka http://panoramix.ift.uni.wroc.pl/~maq/eng/ |
July 8, 2004, 13:47 |
Re: central, upwind, UTOPIA, staggered grids
Hi there,
Check the work of Morinishi et al. (Journal of Computational Physics, 2 articles: 1998 and 2004). The purpose of these 2 articles is to show that if you use a Kinetic Energy Conservative Scheme (it is possible to do so with the staggered mesh scheme), then you don't need any dissipation (or a dissipative scheme) to stabilize the code!! This is of great importance when you deal with turbulent flows (for example using LES modeling) since even the slightest amount of dissipation has a negative impact on the solution. If hope this helps. Sincerely, Frederic Felten. |
July 8, 2004, 14:02 |
Ok, will try this, it will be interesting to have solution without any stabilisation procedures.
Thank you. |
When to use upwind or central differencing schemes? | quarkz | Main CFD Forum | 6 | August 19, 2011 03:24 |
Upwind, central, QUICK scheme for Re~10000 | quarkz | Main CFD Forum | 4 | June 23, 2011 15:04 |
Second order upwind is not UPwind!!! | Far | CFX | 9 | May 31, 2011 08:21 |
Central Difference vs Upwind Defference | S. Balasubramanyam | Main CFD Forum | 5 | January 16, 2002 01:58 |
Staggered grids for compressible flow? | Frank Muldoon | Main CFD Forum | 4 | October 23, 1998 09:50 |
