Blottner Coefficients
Old   August 26, 2010, 07:03
Default Blottner Coefficients
Freddie Sizer
f_sizer is on a distinguished road
I have been working with a CFD code that requires Blottner coefficients as an input. These are not easy to come by, but I've written a simple program in Scilab that calculates the coefficients for you.
The user inputs required are three temperatures and their corresponding viscosities, which are available on the NIST website.
http://webbook.nist.gov/chemistry/fluid/
The output is given in the x vector as the Blottner Coefficients A,B and C. (x(1)=A, x(2)=B etc.)
As an example I have included data for Helium at 1bar.
//Blottner
T1=100;
T2=800;
T3=1500;
u1=6.9644e-06;
u2=3.5932e-05;
u3=5.4056e-05;
//Calculating Blottner viscosity coefficients for He at 1bar
A=[(log(T1))^2 log(T1) 1 ; (log(T2))^2 log(T2) 1; (log(T3))^2 log(T3) 1];
u=[log(u1)-log(0.1); log(u2)-log(0.1); log(u3)-log(0.1)];
x=lusolve(sparse(A),u);
T=[10:10:1500]';
mu=0.1*exp((log(T)*x(1)+x(2)).*log(T)+x(3));
//Calculating Sutherland Viscosity
eta = ((mu0*(T0+C)).*((T./T0)^(3/2)))./(T+C);
//Import Helium data from NIST file
HEV=fscanfMat('HeliumNISTonebar.txt');
plot(T,mu,HEV(:,1),HEV(:,2))
The attached .txt file was taken from the NIST site by simply copying the html output option into excel, deleting not needed columns, and saving as .txt.
Matlab users will need to exchange the lusolve function for the gaussian elimination equivalent in Matlab.
I hope it helps someone!
f_sizer is offline   Reply With Quote
Calculate aerodynamic coefficients with openfoam using only opensource programs Xwang OpenFOAM 20 May 20, 2016 11:26
how to calculate the viscous and inertial resistance coefficients? omurakbayir FLUENT 1 November 22, 2010 22:36
Computing aerodynamic coefficients on bidimensional sections in 3D problems Aragon FLUENT 0 July 22, 2009 04:07
tube bank inertial resistance coefficients Brian FLUENT 0 September 8, 2004 09:04
closure coefficients in 2-eq. turb. models Michael Main CFD Forum 2 December 8, 2003 12:15
