References on Water-Air CFD Simulation
Old   September 15, 2004, 17:14
Default References on Water-Air CFD Simulation
AAM
I'am interested in doing the simulation of the interaction of a solid object moving towards a fluid region (Water). See diagram below. The interest is in the evolution of the free surface of water as it passes the solid. The geometry is 3D and I will use a commercial software.
a).-Water Region______ V<----Solid Object
For the simulation. The Solid is considered to be static and the fluid (Water) moving toward the object as indicated in the diagram below.
b).-Water Region______---->V _____Solid Object
c).-AirRegion/Water Region______---->V _____Solid Object
I have the option of simulating only the flow of water, in this case I am in the presence of a free surface flow problem. On the other hand I can simulate both, water and air flows. For this case The problem is Two-pase flow one, which will be more complicated to simulate and the need to define precisely the interface and interaction of the two fluids.
Does anybody could give references that describe the solution of this type of problems or give some hints about the simulation, such as to model only the free surface flow or the two phase flow.?
Thanks in advance for your kind help.
AAM
Article references for the Tutorial 17: Air Conditioning Simulation amscosta CFX 2 July 16, 2009 07:51
air bubble is disappear increasing time using vof xujjun CFX 9 June 9, 2009 07:59
Separation phenomenon of water, droplet and air Raymond CFX 0 July 9, 2004 22:59
moving water from a chamber using air Matt Mason CFX 0 December 2, 2003 19:46
Where do we go from here? CFD in 2001 John C. Chien Main CFD Forum 36 January 24, 2001 21:10
