Regarding Airfoil Design
Old   December 28, 2010, 15:05
Default Thank you
logesh velusamy
flyerlogesh is on a distinguished road
Thank you Friends
Last edited by flyerlogesh; January 2, 2011 at 04:06. Reason: I received My answer
flyerlogesh is offline   Reply With Quote
Old   December 28, 2010, 23:40
D
bhatiadinesh is on a distinguished road
Hi Logesh,
Although I am not an expert on this, but from what I have seen, you need to chose the blade profile first, by whih I mean, C4, or NACA or any such types, also you have to decide on the type of camber to be given viz. circular arc or such other types. These are the most important aspects of blade design which affect your blade performance.
Once you have decided these formulae for atleast the standard Circular Arc C4's are definitely available onlie, which you canuse to generate you blade profile using by either a small code ( which you may write or maybe available online ) or jut using Excel
-Dinesh
bhatiadinesh is offline   Reply With Quote
Old   December 29, 2010, 01:19
Default Blade Design
A. S.
apoorv is on a distinguished road
Hi Logesh
Can you tell me the institute you are associated with. There is a book by Aungier regarding Axial Compressor Design and Analysis, that has basic blade design method. There is a NASA report by Crouse for Double Circular arc compressor design on inclined/conical surfaces. Both of them could be of help to you.
I have a basic blade design tool for C4 circular arc profiles based on inlet & outlet angle and location for maximum thickness. But I think you where looking for parabolic meanline tool, which you can make with help of Aungier's book.
Regards
Apoorv
apoorv is offline   Reply With Quote
Old   January 2, 2011, 04:00
logesh velusamy
Thank you very much friends. I will refer as the books which you have suggested.
Airfoil design in solidworks/floworks zelito FloEFD, FloWorks & FloTHERM 15 March 24, 2011 21:00
I need help with an unusual airfoil design!! mugsy OpenFOAM 0 September 22, 2009 18:15
Airfoil boundary condition Frank Main CFD Forum 1 April 21, 2008 18:36
Airfoil design khairy FLUENT 6 April 28, 2005 18:19
Info: Short Course On Thermal Design of Electronic Equipment Arnold Free Main CFD Forum 0 August 10, 1999 10:18
