the problem about the volecity from fluent?
Old   March 15, 2011, 21:05
Default the problem about the volecity from fluent?
dongliang
edongliang is on a distinguished road
hi everyone:
I want get the velocity of every cell,and get the velocity from Fluent(export...solution ....ASCII),But i cannot know the relationship between the velocity and the cell.
for example the mesh have 10,000 cells,but i get from fluent the number of the vecolity are larger the 10,000,why?
if i only want to get the of velocity of tetrahedron cell(the mesh is unstructure and the 3d element only tetrahedron ) ,how can i do?
thank your!
edongliang is offline   Reply With Quote
Old   March 15, 2011, 23:39
Raashid Baig
cfd_newbie is on a distinguished road
Originally Posted by edongliang View Post
hi everyone:
thank your!
Hi are you sure that fluent is exporting cell velocity data and not the node velocity data? You mentioned that the number of velocity is larger than 10,000 but by how much.
Also I think what you are trying to do could very well be done in a CFD post-processors. If you do not have access to a commercial post-processor you can you free and open source Paraview (www.paraview.org)
cfd_newbie is offline   Reply With Quote
Problem in IMPORT of ICEM input file in FLUENT csvirume FLUENT 2 September 9, 2009 01:08
Fluent boundary conditions problem bobo FLUENT 2 July 3, 2009 06:28
Fluent parallel license problem brothershuai Main CFD Forum 0 July 1, 2009 15:41
Problem in running fluent 6.3 (64 bit) on ubuntu 8.1 (64 bit) Mir5 FLUENT 3 April 29, 2009 10:32
Fluent problem Z FLUENT 1 April 8, 2005 04:22
