what's R-refinement and h-refinement?
Like Tree1Likes
  • 1 Post By iilw1314
Old   March 28, 2011, 11:46
Smile what's R-refinement and h-refinement?
L.Y LIN
iilw1314 is on a distinguished road
plz explain them ,thanks.
iilw1314 is offline   Reply With Quote
Old   March 28, 2011, 11:50
L.Y LIN
ok,i have found the answer:
In the first, h-refinement, increased local resolution
of solution features is accomplished by recursively subdividing mesh cells where needed. This
technique is used by both the Cartesian grid and the unstructured grid communities. In the second category,
r-refinement, the number of mesh nodes and cells remains constant, but nodes are relocated to areas where
needed to increase resolution. It can be argued that each type of reŽnement will produce acceptable resolution
improvement under appropriate usage.
8cold8hot likes this.
[snappyHexMesh] Number of cells in mesh don't match with size of cellLevel colinB OpenFOAM Meshing & Mesh Conversion 14 December 12, 2018 08:07
[snappyHexMesh] snappyHexMesh won't work - zeros everywhere! sc298 OpenFOAM Meshing & Mesh Conversion 2 March 27, 2011 21:11
[snappyHexMesh] snappyHexMesh aborting Tobi OpenFOAM Meshing & Mesh Conversion 0 November 10, 2010 03:23
[snappyHexMesh] sMH refinement level subhkirti OpenFOAM Meshing & Mesh Conversion 0 October 13, 2010 04:10
[snappyHexMesh] external flow with snappyHexMesh chelvistero OpenFOAM Meshing & Mesh Conversion 11 January 15, 2010 19:43
