Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Bugs
Changing the name of a boundary condition produces errors
Old   December 27, 2010, 16:09
Default Changing the name of a boundary condition produces errors
George Pichurov
jorkolino is on a distinguished road
when I try to recompile a boundary condition from the OF sources by just changing its name as a parameter in the makePatchTypeFieldsTypedefs() and makePatchFIelds() functions, I get following errors when executing wmake libso :
error: expected initializer before '<' token.
error: 'mixedFvPatchScalarField' has not been declared
error: 'mixedFvPatchScalarFIeld' was not declared in this scope
error: 'mixedFvPatchVectorFIeld' ...
The boundary condition otherwise compiles well when using the original name (in this case mixed). I tried replacing the name with many allowed names, including such that are present in OF (like fixedValue), with the same error message.
jorkolino is offline   Reply With Quote
Old   January 5, 2011, 21:25
Retired Super Moderator
Bruno Santos
Greetings George,
It's not advisable to change boundary conditions in the core libraries of OpenFOAM. It's best to create a new library for adding a new boundary condition.
Secondly, "mixedFvPatchScalarField" and "mixedFvPatchScalarFIeld" are Not the same thing, in the eyes of the compiler!! C/C++ is case sensitive, requiring the user to be very cautious of what he or she is doing! Same goes for CFD
For more information on how to add a new boundary condition, see this page in the unofficial wiki: HowTo Adding a new boundary condition
Best regards and good luck!
Bruno
Old   January 6, 2011, 03:14
George Pichurov
thanks for reply. I had a problem compiling my own library, the problem turned out to be that the file names did not follow a particular syntax: mainly that the name of the B.C. should be the same as the file name prefix before fvPtchField. I.e. if i want a B.C called mixedGeorge, then my file names shoud be mixedGeorgefvPatchField[s].C[H]. Just changing the file names helped to solve the issue. The word "...FIeld.." in my message above was just a typo in the forum.
Regards,
George
inlet velocity boundary condition murali CFX 5 August 3, 2012 08:56
[Gmsh] Import problem ARC OpenFOAM Meshing & Mesh Conversion 0 February 27, 2010 10:56
SymmetryPlane Boundary Condition raytracer OpenFOAM Running, Solving & CFD 0 July 11, 2008 17:04
Airfoil boundary condition Frank Main CFD Forum 1 April 21, 2008 18:36
Rotating interpolated boundary condition hani OpenFOAM Running, Solving & CFD 0 July 4, 2006 07:09
