[swak4Foam] source code hg server not working?
Like Tree3Likes
  • 1 Post By wyldckat
  • 2 Post By gschaider
Old   February 19, 2018, 10:58
Default source code hg server not working?
Joachim Herb
jherb is on a distinguished road
today, I tried to clone the source code of swak4foam from http://hg.code.sf.net/p/openfoam-extend/swak4Foam but it did not work.
hg clone -v  http://hg.code.sf.net/p/openfoam-extend/swak4Foam openfoam-extend-swak4Foam
requesting all changes
adding changesets
adding manifests
transaction abort!
rollback completed
abort: connection ended unexpectedly
The command stalls in accessing "manifests":
manifests [================>                           ] 2751/3351 07s
Also downloading a snapshot from sourceforge did not work. Is this just me or is there a problem with the serer?
Is there a (git) mirror which is up to date?
Thank you for your help
Joachim
jherb is offline   Reply With Quote
Old   February 19, 2018, 11:02
Retired Super Moderator
Bruno Santos
https://github.com/Unofficial-Extend...-swak4Foam-dev should be properly synced, at least it has the same last commit as in the link you provided.
edit: It was just mere luck that I answered 4 minutes after your post...
jherb likes this.
Old   February 21, 2018, 18:14
Joachim Herb
Thank you for your help. The mirror works as expected. (if you correctly switch branches)
Old   February 25, 2018, 12:12
Assistant Moderator
Bernhard Gschaider
adding changesets
adding manifests
transaction abort!
rollback completed
Joachim
I guess the reason was that SourceForge moved their serivces to a different data-center in the last weeks https://twitter.com/sfnet_ops/status/966166935833600000
If you plan to ever contribute to swak4Foam then the git-archive is a dead-end street. Rather use https://bgschaid@bitbucket.org/bgsch...iginal-repo-on (which is usually getting a push at the same time as the sourceforge-repo)
wyldckat and jherb like this.
Note: I don't use "Friend"-feature on this forum out of principle. Ah. And by the way: I'm not on Facebook either. So don't be offended if I don't accept your invitation/friend request
[OpenFOAM.org] Error creating ParaView-4.1.0 OpenFOAM 2.3.0 tlcoons OpenFOAM Installation 13 April 20, 2016 17:34
[Other] How to use finite area method in official OpenFOAM 2.2.0? Detian Liu OpenFOAM Meshing & Mesh Conversion 4 November 3, 2015 03:04
Problem compiling a custom Lagrangian library brbbhatti OpenFOAM Programming & Development 2 July 7, 2014 11:32
Trouble compiling utilities using source-built OpenFOAM Artur OpenFOAM Programming & Development 14 October 29, 2013 10:59
centOS 5.6 : paraFoam not working yossi OpenFOAM Installation 2 October 9, 2013 01:41
