July 30, 2012, 04:29 |
Setting environment variables: bash issue
av
Rep Power: 14 |
I would like to automate environment initialization prior to OpenFOAM use. I wrote the following bash script, but it doesn't work at all. Environment is only set inside script, when it exit the script and goes back to console, nothing changes, no variable has been defined. #!/bin/bash source /opt/OpenFOAM/OpenFOAM-2.1.1/etc/bashrc source $HOME/.bashrc cd $FOAM_RUN Do you know how can I keep environment after script execution ? Thanks for your help. Xavier |
Windows Environment variables- to solve problems in compiling UDF in Fluent | Modest Cat | Fluent UDF and Scheme Programming | 39 | May 18, 2016 10:33 |
Issue with tcsh vs bash shells | Gary_cfd | OpenFOAM Installation | 1 | June 21, 2012 17:06 |
CFX11 + Fortran compiler ? | Mohan | CFX | 20 | March 30, 2011 18:56 |
Setting up Enviromental Variables | hasan_hzl | ANSYS | 0 | December 5, 2009 04:46 |
FloWorks (Flow Express) Volume Goal Setting Issue | rbigelow | FloEFD, FloWorks & FloTHERM | 1 | November 16, 2009 01:32 |
