How can download older versions of OF?
Like Tree2Likes
  • 1 Post By wyldckat
Old   May 5, 2013, 08:46
Default How can download older versions of OF?
immortality's Avatar
Ehsan
immortality is on a distinguished road
how can install older versions without removing later ones?
Injustice Anywhere is a Threat for Justice Everywhere.Martin Luther King.
To Be or Not To Be,Thats the Question!
The Only Stupid Question Is the One that Goes Unasked.
immortality is offline   Reply With Quote
Old   May 5, 2013, 08:48
Retired Super Moderator
Bruno Santos
I've written about this several times... one of them here: Advanced tips for working with the OpenFOAM shell environment
Old   May 5, 2013, 08:59
Ehsan
no as you know my other versions of OF were deleted when I wanted to install a anti-filter software.I just download them again.but in oenfoam.org i see only 2.2.0 version for download or maybe i haven't look at it carefully?
Old   May 5, 2013, 09:07
Bruno Santos
If you need OpenFOAM 2.1.1, follow these instructions: http://www.openfoam.org/archive/2.1....oad/ubuntu.php
Old   May 5, 2013, 10:23
Ehsan
dear Bruno I used alias as you have told.but no command executed now:
ehsan@Ehsan-com:~/Desktop/Huge_reservoir_filling$ runPlot 4 rhoCentralFoamModified
Usage
  pyFoamPlotRunner.py [options] <foamApplication> <caseDir> <caseName> [foamOptions]
pyFoamPlotRunner.py: error: Too few arguments (3 needed, 1 given)
ehsan@Ehsan-com:~/Desktop/Huge_reservoir_filling$ decomPosePar
decomPosePar: command not found
ehsan@Ehsan-com:~/Desktop/Huge_reservoir_filling$ of220
of220: command not found
ehsan@Ehsan-com:~/Desktop/Huge_reservoir_filling$ alias of220='. /opt/openfoam220/etc/bashrc'
sorry.I had written alias commands in shell not in bashrc.now resolved.
Old   May 5, 2013, 10:36
Bruno Santos
  1. What are the last 10 lines of the file "~/.bashrc"?
  2. Did you start a new terminal?
  3. It's "decomposePar", not "decomPosePar".
Old   May 5, 2013, 10:55
Ehsan
is it true and as you had told?
if [ -f ~/.bash_aliases ]; then
    . ~/.bash_aliases
fi
# enable programmable completion features (you don't need to enable
# this, if it's already enabled in /etc/bash.bashrc and /etc/profile
# sources /etc/bash.bashrc).
if [ -f /etc/bash_completion ] && ! shopt -oq posix; then
    . /etc/bash_completion
fi
#. /opt/openfoam220/etc/bashrc
#. /opt/openfoam211/etc/bashrc
#. /opt/openfoam210/etc/bashrc
alias of210='. /opt/openfoam210/etc/bashrc'
export PATH="$PATH:/home/ehsan/Desktop/codes"
Old   May 5, 2013, 11:22
Bruno Santos
The contents of the file "~/.bashrc" look OK. There doesn't seem to be any problem with it.
Whenever you start a new terminal window (or tab), run:
of220
or:
of210
for activating the respective environment.
If you need the other version of OpenFOAM to work with, start a new terminal and activate said version. You'll only be able to use one version at a time per terminal.
So, if you have not yet started a new terminal, you better start a new one now!
immortality likes this.
Old   May 5, 2013, 11:36
Ehsan
what do you mean by "tab"?is it a way to move between terminals?(I try to learn new things)
Old   May 5, 2013, 11:42
Bruno Santos
It's been so much time since you've been working on Linux, and you still don't know about terminal tabs?
It would be wonderful if a tool for FoamToTecplot is available luckyluke OpenFOAM Post-Processing 165 November 27, 2012 06:54
how to open star ccm 6.04 version file in older versions pritam.edke Siemens 2 June 25, 2012 03:14
Older versions compatibility (1.5 vs 2.1) ? xerces8 OpenFOAM 2 May 24, 2012 08:20
Can't get older versions of OpenFOAM fabioc OpenFOAM Installation 4 February 7, 2012 09:13
Older Versions distributions jaswi OpenFOAM 2 July 3, 2007 11:51
