Unable to install OpenFOAM 1.6-ext
Like Tree1Likes
Old   November 18, 2013, 12:47
Default Unable to install OpenFOAM 1.6-ext
ok
Maimouna is on a distinguished road
Hi all,
currently, I'm working in OpenFOAM 2.2.1. Now,I'm trying to install OpenFOAM 1.6-ext to work with icoFsiFoam tutorials. Now, I got problem with terminal window, when I open it, it gives me directly the following error
bash: /opt/OpenFOAM-1.6-ext/bin/foamEtcFile: No such file or directory
bash: /opt/OpenFOAM-1.6-ext/bin/foamCleanPath: No such file or directory
bash: /opt/OpenFOAM-1.6-ext/etc/settings.sh: No such file or directory
bash: /opt/OpenFOAM-1.6-ext/etc/aliases.sh: No such file or directory
maimouna@maimouna-desktop:~$
What's the problem?
How can I solve that? and if I would like to re-install OpenFOAM 1.6-ext, how can I do it?
I tried to remove it and install it again, but isn't coming.
I really appreciate your help.
Regards
Maimouna
Maimouna is offline   Reply With Quote
Old   November 18, 2013, 14:43
Default OpenFoam 1.6-ext installation problem
Bernhard Linseisen
Linse is on a distinguished road
Dear Maimouna,
1.) Please try to change the title of your post/thread to something more narrative, such as OpenFoam 1.6-ext installation bash error
2.) My first guess concerning your problem would be that something with the .bashrc is wrong. Either the files are not existent on your system because you removed them, or one of the paths, maybe the one in OpenFOAM-1.6-ext/etc/bashrc is pointing the wrong way.
A long shot from my side: Did you really install into /opt instead of $HOME?
At the moment all is speculative, I would suggest attaching your .bashrc (without any passwords and such, of course) to your next post, then one could see if there already is a fundamental problem in there. Ideally attach the OpenFOAM-1.6-ext/etc/bashrc as well...
Linse is offline   Reply With Quote
Old   November 19, 2013, 10:29
Default installation problem OpenFOAM-1.6-ext
ok
Hi foamers,
I already worked in OpenFOAM 2.2.1 on Ubuntu 12.04 for different cases. Now, I'm trying to install OpenFOAM 1.6-ext to work with icoFsiFoam and different cases in FSI.
I did the following steps to show you if I'm doing well or not:
1. I had OpenFOAM folder inside $HOME directory
2. I already installed OpenFOAM-2.2.1 in this directory and it is working properly.
3. Inside OpenFOAM directory, I installed OpenFOAM 1.6-ext by following instructions given in
http://openfoamwiki.net/index.php/In...1.6-ext/Ubuntu
4. When I was in step number 10 to check if everything going well by typing
gedit log.AllMake
it gives me the following error
Error: Directory does not exist /opt/ThirdParty-2.2.1
Error: Current directory is not $WM_THIRD_PARTY_DIR
The environment variables are inconsistent with the installation.
Check the OpenFOAM entries in your dot-files and source them.
I don't know what are the problems and how to solve it?
Moreover, when I go back to the OpenFOAM directory where I install OpenFOAM 1.6-ext, I found two locked folders
/home/maimouna/OpenFOAM/OpenFOAM-1.6-ext
and
/home/maimouna/OpenFOAM/OpenFOAM-1.6-ext.git
Why they are locked?
I tried many times to delete them to re-install OpenFOAM 1.6-ext again , but gives me messages can't move them to recycle bin?
Can you help me please to get answers for all my questions.
Old   November 19, 2013, 17:05
Retired Super Moderator
Bruno Santos
Quick answer @Maimouna: Please read and study this blog post: Advanced tips for working with the OpenFOAM shell environment
Old   November 20, 2013, 06:18
ok
Dear Bruno,
many thanks for your reply. I have problem in terminal window, directly it gives me these errors when starts
How can I solve it?
OpenFOAM-1.6-ext installation doesn't complete. I tried to remove it and install it again, but it isn't coming I really confused and I don't know the problem?
Old   November 20, 2013, 06:28
ok
Also, after I installed OpenFOAM-1.6-ext, even it is not completed, tutorials in previous OpenFOAM 2.2.1 not working now. When I type blockMesh in some cases such as icoFoam/cavity it gives me this error --> FOAM FATAL ERROR in Foam::findEtcFiles() : could not find mandatory file
'controlDict'
but it was worked properly.
How can I solve this error?
Old   November 20, 2013, 06:44
Bruno Santos
Like I wrote above:
Originally Posted by wyldckat View Post
If you read that blog post and study it, you'll understand how to fix this problem you're having!
Old   November 20, 2013, 07:31
Bernhard Linseisen
To me it seems to be a problem with your OpenFOAM-1.6-ext/etc/bashrc
Try to find the line where you can set the installation location ($FOAM_INSTALL_DIR ?) . The setting at the moment seems to be /opt.
Usually you will find a commented line shortly below where it says $HOME/OpenFOAM.
Just comment the /opt-line and uncomment the $HOME/OpenFOAM-line and you should be much further in your compilation.
Old   November 20, 2013, 08:33
ok
I read the tips in Advanced tips for working with the OpenFOAM shell environment, but the problem is I have read only bashrc file, so I couldn't save any changes on it.
What to do?
I got locked folder of OpenFOAM1.6-ext and OpenFOAM-1.6-ext.git.
I tried to remove the previous installation to install OpenFOAM-1.6-ext again, but could't. How can I solve this problem?
Old   November 20, 2013, 08:35
ok
My planning no to re-install OpenFOAM-1.6-ext.
How can I, the problem is with that locked folders?
Old   November 20, 2013, 16:31
Bruno Santos
Greetings to all!
I was in a hurry and couldn't go into details in the previous posts.
@Maimouna:
Originally Posted by Maimouna View Post
I wrote "read and study", not simply "read"
What I mean by this, is that this blog post is not something that can be read in 5 minutes or less. In order to understand it, you need to read and try it out on the command line and read again and try again, until you can understand what it all means. This will take somewhere between 10 and 20 minutes, not just 5 minutes.
As for the problem at hand, the first issue is this:
Traditionally, you are simply instructed to add something like the following line to the file "~/.bashrc":
. $HOME/OpenFOAM/OpenFOAM-X.Y.Z/etc/bashrc
Or:
source $HOME/OpenFOAM/OpenFOAM-X.Y.Z/etc/bashrc
The dot at the beginning of the line does the same as source, namely it will run the file as if it where a local script, therefore setting all of the necessary environment variables.
Note: The file "~/.bashrc" is the same as "$HOME/.bashrc", which you can see the location for it by running:
echo $HOME/.bashrc
In other words, you should first edit the file "$HOME/.bashrc".
Once it's open for editing, find these lines or similar ones:
. /opt/openfoam221/etc/bashrc
. $HOME/OpenFOAM/OpenFOAM-1.6-ext/etc/bashrc
Replace these 2 lines with these two:
alias of221='. /opt/openfoam221/etc/bashrc'
alias of16ext='. $HOME/OpenFOAM/OpenFOAM-1.6-ext/etc/bashrc'
now whenever you start a new terminal/console window or tab, the OpenFOAM environment is not available by default. You have to run one of the alias commands to activate the desired environment. So, start a new terminal and run one of the alias commands...
For example, to use OpenFOAM 2.2.1:
  1. Start a new terminal.
  2. Run this command (the alias command):
    of221
  3. And the environment for OpenFOAM 2.2.1 is now ready to use in this terminal window.
As for using OpenFOAM 1.6-ext:
  1. Start a new terminal (DO NOT USE the same terminal as the one from OpenFOAM 2.2.1!).
    of16ext
  3. And the environment for OpenFOAM 1.6-ext is now ready to use in this terminal window.
If my guess is correct, this should solve the problem.
Best regards,
Bruno
Old   November 22, 2013, 05:49
Default Error with gedit log.AllMake during OpenFOAM-1.6-ext installation
  #12
ok
Dear OpenFOAM users
I'm working in OpenFOAM-2.2.1 on Ubuntu 12.04. My planning is to use icoFsiFoam solver which is located in OpenFOAM-1.6-ext. That's why I'm installing OpenFOAM-1.6-ext in my machine.
I got the followig error in log.AllMake file
I couldn't understand the problem.
For more details, can you please check OpenFOAM-1.6-ext/etc/.bashrc file below (sorry I couldn't attach it, it gives me attached error)
#----------------------------------*-sh-*--------------------------------------
# \\      /  F ield         | OpenFOAM: The Open Source CFD Toolbox
#  \\    /   O peration     |
#   \\  /    A nd           | Copyright held by original author
#    \\/     M anipulation  |
# License
#     This file is part of OpenFOAM.
#     OpenFOAM is free software; you can redistribute it and/or modify it
#     under the terms of the GNU General Public License as published by the
#     Free Software Foundation; either version 2 of the License, or (at your
#     option) any later version.
#     OpenFOAM is distributed in the hope that it will be useful, but WITHOUT
#     ANY WARRANTY; without even the implied warranty of MERCHANTABILITY or
#     FITNESS FOR A PARTICULAR PURPOSE.  See the GNU General Public License
#     for more details.
#     You should have received a copy of the GNU General Public License
#     along with OpenFOAM; if not, write to the Free Software Foundation,
#     Inc., 51 Franklin St, Fifth Floor, Boston, MA 02110-1301 USA
# Script
#     etc/bashrc
# Description
#     Startup file for OpenFOAM
#     Sourced from ~/.profile or ~/.bashrc
#     Should be usable by any POSIX-compliant shell (eg, ksh)
export WM_PROJECT=OpenFOAM
export WM_PROJECT_VERSION=1.6-ext
# helps to easily write #ifdefs to detect a dev-version
export FOAM_DEV=1
# USER EDITABLE PART
# either set $FOAM_INST_DIR before sourcing this file or set
#    $foamInstall below to where OpenFOAM is installed
# Location of FOAM installation
foamInstall=$HOME/$WM_PROJECT
# foamInstall=~$WM_PROJECT
# foamInstall=/usr/local/$WM_PROJECT
# foamInstall=/opt/$WM_PROJECT
# foamInstall=/usr/lib
# END OF (NORMAL) USER EDITABLE PART
# note the location for later use (eg, in job scripts)
: ${FOAM_INST_DIR:=$foamInstall}; export FOAM_INST_DIR
# The old dirs to be cleaned from the various environment variables
# - remove anything under top-level directory.
# NB: the WM_PROJECT_INST_DIR might not be identical between versions
foamOldDirs="$FOAM_INST_DIR $HOME/$WM_PROJECT/$USER"
if [ "$WM_PROJECT_INST_DIR" != "$FOAM_INST_DIR" ]
then
    foamOldDirs="$WM_PROJECT_INST_DIR $foamOldDirs"
fi
# Location of site/user files
export WM_PROJECT_INST_DIR=$FOAM_INST_DIR
export WM_PROJECT_DIR=$WM_PROJECT_INST_DIR/$WM_PROJECT-$WM_PROJECT_VERSION
: ${WM_PROJECT_USER_DIR:=$HOME/$WM_PROJECT/$USER-$WM_PROJECT_VERSION}; export WM_PROJECT_USER_DIR
# Location of third-party software
#: ${WM_THIRD_PARTY_DIR=$WM_PROJECT_INST_DIR/ThirdParty-$WM_PROJECT_VERSION}; export WM_THIRD_PARTY_DIR
: ${WM_THIRD_PARTY_DIR=$WM_PROJECT_DIR/ThirdParty}; export WM_THIRD_PARTY_DIR
# Source files, possibly with some verbosity
_foamSource()
   while [ $# -ge 1 ]
   do
      [ "$FOAM_VERBOSE" -a "$PS1" ] && echo "Sourcing: $1"
      . $1
      shift
   done
# Add in preset user or site preferences:
foamPrefs=`$WM_PROJECT_DIR/bin/foamEtcFile prefs.sh` && _foamSource $foamPrefs
unset foamPrefs
# Evaluate command-line parameters
while [ $# -gt 0 ]
do
    case "$1" in
        # name=       -> unset name
        eval "unset ${1%=}"
        # name=value  -> export name=value
        eval "export $1"
    esac
    shift
done
# Operating System/Platform
# WM_OSTYPE = POSIX | ????
: ${WM_OSTYPE:=POSIX}; export WM_OSTYPE
# Compiler: set to Gcc, Gcc43 or Icc (for Intel's icc)
: ${WM_COMPILER:=Gcc}; export WM_COMPILER
export WM_COMPILER_ARCH=
export WM_COMPILER_LIB_ARCH=
# Compilation options (architecture, precision, optimised, debug or profiling)
: ${WM_NCOMPPROCS:=2}; export WM_NCOMPPROCS
# WM_ARCH_OPTION = 32 | 64
: ${WM_ARCH_OPTION:=64}; export WM_ARCH_OPTION
# WM_PRECISION_OPTION = DP | SP
: ${WM_PRECISION_OPTION:=DP}; export WM_PRECISION_OPTION
# WM_COMPILE_OPTION = Opt | Debug | Prof
: ${WM_COMPILE_OPTION:=Opt}; export WM_COMPILE_OPTION
# WM_MPLIB = | OPENMPI | MPICH | MPICH-GM | HPMPI | GAMMA | MPI | QSMPI
: ${WM_MPLIB:=OPENMPI}; export WM_MPLIB
# Run options (floating-point signal handling and memory initialisation)
export FOAM_SIGFPE=
# export FOAM_SETNAN=
# Detect system type and set environment variables appropriately
export WM_ARCH=`uname -s`
case $WM_ARCH in
Linux)
    WM_ARCH=linux
    # compiler specifics
    case `uname -m` in
    i686)
    x86_64)
        case $WM_ARCH_OPTION in
        32)
            export WM_COMPILER_ARCH='-64'
            export WM_CFLAGS='-m32 -fPIC'
            export WM_CXXFLAGS='-m32 -fPIC'
            export WM_LDFLAGS='-m32'
        64)
            WM_ARCH=linux64
            export WM_COMPILER_LIB_ARCH=64
            export WM_CFLAGS='-m64 -fPIC'
            export WM_CXXFLAGS='-m64 -fPIC'
            export WM_LDFLAGS='-m64'
            echo Unknown WM_ARCH_OPTION $WM_ARCH_OPTION, should be 32 or 64
        esac
    ia64)
        WM_ARCH=linuxIA64
        export WM_COMPILER=I64
    mips64)
        WM_ARCH=SiCortex64
        export WM_CFLAGS='-mabi=64 -fPIC'
        export WM_CXXFLAGS='-mabi=64 -fPIC'
        export WM_LDFLAGS='-mabi=64 -G0'
        export WM_MPLIB=MPI
    ppc64)
        WM_ARCH=linuxPPC64
        echo Unknown processor type `uname -m` for Linux
    esac
Darwin)
    # this makes certain things easier
    export WM_ARCH_BASE=darwin
    case `uname -p` in
    powerpc)
    export WM_ARCH=darwinPpc
    i386)
    export WM_ARCH=darwinIntel
        echo "This seems to be neither an Intel-Mac nor a PPC-Mac please tell me the output of 'uname -p'. Bernhard."
    export WM_ARCH=darwinUnknown
    esac
    32)
    64)
        export WM_ARCH=${WM_ARCH}64
    esac
    # Make sure that binaries use the best features of the used OS-Version
    export MACOSX_DEPLOYMENT_TARGET=`sw_vers -productVersion`
    if [ "$compilerInstall" == "System" ]
    then
        # Use Mac-Ports-Compiler instead of Apple-gcc-4.2
    case $WM_COMPILER in
    Gcc43)
            export WM_CC='gcc-mp-4.3'
        export WM_CXX='g++-mp-4.3'
        Gcc44)
            export WM_CC='gcc-mp-4.4'
        export WM_CXX='g++-mp-4.4'
        Gcc45)
            export WM_CC='gcc-mp-4.5'
        export WM_CXX='g++-mp-4.5'
            export WM_COMPILER=
        esac
    fi
SunOS)
    WM_ARCH=SunOS64
    export WM_MPLIB=FJMPI
*)        # an unsupported operating system
    cat <<USAGE
    Your "$WM_ARCH" operating system is not supported by this release
    of OpenFOAM. For further assistance, please contact www.extend-project.de
USAGE
esac
# Clean standard environment variables (PATH, LD_LIBRARY_PATH, MANPATH)
cleanProg=$WM_PROJECT_DIR/bin/foamCleanPath
#- Clean PATH
cleanEnv=`$cleanProg "$PATH" "$foamOldDirs"` && PATH="$cleanEnv"
#- Clean LD_LIBRARY_PATH
cleanEnv=`$cleanProg "$LD_LIBRARY_PATH" "$foamOldDirs"` && LD_LIBRARY_PATH="$cleanEnv"
#- Clean DYLD_LIBRARY_PATH
if [[ "$WM_ARCH_BASE" == "darwin" ]]
then
    cleanEnv=`$cleanProg "$DYLD_LIBRARY_PATH" "$foamOldDirs"` && DYLD_LIBRARY_PATH="$cleanEnv"
fi
#- Clean MANPATH
cleanEnv=`$cleanProg "$MANPATH" "$foamCleanDirs"` && MANPATH="$cleanEnv"
export PATH LD_LIBRARY_PATH MANPATH
# Source project setup files
_foamSource $WM_PROJECT_DIR/etc/settings.sh
_foamSource $WM_PROJECT_DIR/etc/aliases.sh
# Source user setup files for optional packages
# _foamSource $WM_PROJECT_DIR/etc/apps/paraview/bashrc
# _foamSource $WM_PROJECT_DIR/etc/apps/paraview3/bashrc
# _foamSource $WM_PROJECT_DIR/etc/apps/ensight/bashrc
# Clean environment paths again. Only remove duplicates
#- Clean PATH
cleanEnv=`$cleanProg "$PATH"` && PATH="$cleanEnv"
cleanEnv=`$cleanProg "$LD_LIBRARY_PATH"` && LD_LIBRARY_PATH="$cleanEnv"
#- Clean MANPATH
cleanEnv=`$cleanProg "$MANPATH"` && MANPATH="$cleanEnv:"
#- Clean LD_PRELOAD
if [ "$LD_PRELOAD" != "" ]
then
    cleanEnv=`$cleanProg "$LD_PRELOAD"` && LD_PRELOAD="$cleanEnv"
    export LD_PRELOAD
fi
# cleanup environment:
unset cleanEnv cleanProg foamInstall foamOldDirs
unset _foamSource
alias of221='. $HOME/OpenFOAM/OpenFOAM-2.2.1/etc/bashrc'
What can I do to avoid the error?
If I remove OpenFOAM-2.2.1 can install OpenFOAM-1.6-ext, is it solution?
Any solution, would be welcomed.
Regards
Old   November 22, 2013, 17:07
Bruno Santos
Greetings Maimouna,
I did give you the solution in the previous post, but apparently I wasn't clear enough on the instructions...
OK, let me try to explain it like this:
  1. Run this command:
    ls -l $HOME/.bashrc $HOME/OpenFOAM/OpenFOAM-1.6-ext/etc/bashrc
  2. You should now see something like this:
    -rw-r--r--. 1 ofuser ofuser  124 Mar 11  2013 /home/ofuser/.bashrc
    -rw-rw-r--. 1 ofuser ofuser 9869 Nov 22 16:54 /home/ofuser/OpenFOAM/OpenFOAM-1.6-ext/etc/bashrc
    "ofuser" is the user name on the machine I'm using. In your case, it might be "maimouna".
  3. Notice that there are two very different files:
    • "/home/ofuser/.bashrc" - this is the file that is located at "$HOME/.bashrc"
    • "/home/ofuser/OpenFOAM/OpenFOAM-1.6-ext/etc/bashrc" - this is the file that OpenFOAM 1.6-ext has got for setting up 1.6-ext's shell environment.
  4. As you can see, you should have edited the file "$HOME/.bashrc", and not the file "$HOME/OpenFOAM/OpenFOAM-1.6-ext/etc/bashrc".
  5. Therefore:
    1. Edit the file "$HOME/.bashrc".
    2. Once it's open for editing, find these lines or similar ones:
    3. Replace these 2 lines with these two:
    4. Now, once the file "$HOME/.bashrc" is saved and closed:
      • To use OpenFOAM 2.2.1:
          of221
      • As for using OpenFOAM 1.6-ext:
          of16ext
Best regards,
Bruno
Old   November 26, 2013, 09:59
ok
Dear Bruno,
many thanks for your reply and so sorry for my late reply.
when I started of221, it works fine. But when I opened a new terminal for of16ext, it gives me the following comments
maimouna@maimouna-desktop:~$ of16ext
Sourcing: /home/maimouna/OpenFOAM/OpenFOAM-1.6-ext/etc/settings.sh
  Environment variables defined for OpenMPI:
    OPENMPI_BIN_DIR       : /usr/bin
    OPENMPI_LIB_DIR       : /usr/lib/openmpi/lib
    OPENMPI_INCLUDE_DIR   : /usr/lib/openmpi/include /usr/lib/openmpi/include/openmpi
    OPENMPI_COMPILE_FLAGS : -I/usr/lib/openmpi/include -I/usr/lib/openmpi/include/openmpi -pthread
    OPENMPI_LINK_FLAGS    : -pthread -L/usr/lib/openmpi/lib -lmpi -lopen-rte -lopen-pal -ldl -Wl,--export-dynamic -lnsl -lutil -lm -ldl
    MPI_HOME              : /usr
    MPI_ARCH_PATH         : /usr
    OPAL_PREFIX           : /usr
    PINC                  : -I/usr/lib/openmpi/include -I/usr/lib/openmpi/include/openmpi -pthread
    PLIBS                 : -pthread -L/usr/lib/openmpi/lib -lmpi -lopen-rte -lopen-pal -ldl -Wl,--export-dynamic -lnsl -lutil -lm -ldl
Sourcing: /home/maimouna/OpenFOAM/OpenFOAM-1.6-ext/ThirdParty/packages/mesquite-2.1.2/platforms/linux64Gcc46DPOpt/etc/mesquite-2.1.2.sh
    MESQUITE_DIR is initialized to: /home/maimouna/OpenFOAM/OpenFOAM-1.6-ext/ThirdParty/packages/mesquite-2.1.2/platforms/linux64Gcc46DPOpt
Sourcing: /home/maimouna/OpenFOAM/OpenFOAM-1.6-ext/ThirdParty/packages/metis-5.0pre2/platforms/linux64Gcc46DPOpt/etc/metis-5.0pre2.sh
    METIS_DIR is initialized to: /home/maimouna/OpenFOAM/OpenFOAM-1.6-ext/ThirdParty/packages/metis-5.0pre2/platforms/linux64Gcc46DPOpt
Sourcing: /home/maimouna/OpenFOAM/OpenFOAM-1.6-ext/ThirdParty/packages/ParMetis-3.1.1/platforms/linux64Gcc46DPOpt/etc/ParMetis-3.1.1.sh
    PARMETIS_DIR is initialized to: /home/maimouna/OpenFOAM/OpenFOAM-1.6-ext/ThirdParty/packages/ParMetis-3.1.1/platforms/linux64Gcc46DPOpt
Sourcing: /home/maimouna/OpenFOAM/OpenFOAM-1.6-ext/ThirdParty/packages/ParMGridGen-1.0/platforms/linux64Gcc46DPOpt/etc/ParMGridGen-1.0.sh
    PARMGRIDGEN_DIR is initialized to: /home/maimouna/OpenFOAM/OpenFOAM-1.6-ext/ThirdParty/packages/ParMGridGen-1.0/platforms/linux64Gcc46DPOpt
Sourcing: /home/maimouna/OpenFOAM/OpenFOAM-1.6-ext/ThirdParty/packages/libccmio-2.6.1/platforms/linux64Gcc46DPOpt/etc/libccmio-2.6.1.sh
    LIBCCMIO_DIR is initialized to: /home/maimouna/OpenFOAM/OpenFOAM-1.6-ext/ThirdParty/packages/libccmio-2.6.1/platforms/linux64Gcc46DPOpt
Sourcing: /home/maimouna/OpenFOAM/OpenFOAM-1.6-ext/ThirdParty/packages/scotch-5.1.10b/platforms/linux64Gcc46DPOpt/etc/scotch-5.1.10b.sh
    SCOTCH_DIR is initialized to: /home/maimouna/OpenFOAM/OpenFOAM-1.6-ext/ThirdParty/packages/scotch-5.1.10b/platforms/linux64Gcc46DPOpt
Sourcing: /home/maimouna/OpenFOAM/OpenFOAM-1.6-ext/ThirdParty/packages/cmake-2.8.11/platforms/linux64Gcc46DPOpt/etc/cmake-2.8.11.sh
    CMAKE_DIR is initialized to: /home/maimouna/OpenFOAM/OpenFOAM-1.6-ext/ThirdParty/packages/cmake-2.8.11/platforms/linux64Gcc46DPOpt
    M4_DIR is initialized to:
    BISON_DIR is initialized to:
    FLEX_DIR is initialized to:
    ZOLTAN_DIR is initialized to:
    PYTHON_DIR is initialized to:
    QT_DIR is initialized to:
    PARAVIEW_DIR is initialized to: /usr
Sourcing: /home/maimouna/OpenFOAM/OpenFOAM-1.6-ext/etc/aliases.sh
maimouna@maimouna-desktop:~$ cd OpenFOAM/OpenFOAM-1.6-ext
maimouna@maimouna-desktop:~/OpenFOAM/OpenFOAM-1.6-ext$ cd tutorials/incompressible/icoFoam/
maimouna@maimouna-desktop:~/OpenFOAM/OpenFOAM-1.6-ext/tutorials/incompressible/icoFoam$ cd cavity
maimouna@maimouna-desktop:~/OpenFOAM/OpenFOAM-1.6-ext/tutorials/incompressible/icoFoam/cavity$ blockMesh
| \\      /  F ield         | OpenFOAM Extend Project: Open source CFD        |
|  \\    /   O peration     | Version:  1.6-ext                               |
|   \\  /    A nd           | Web:      www.extend-project.de                 |
Build  : 1.6-ext-064a6e9f332e
Exec   : blockMesh
Date   : Nov 26 2013
Time   : 14:47:23
Host   : maimouna-desktop
PID    : 9482
Case   : /home/maimouna/OpenFOAM/OpenFOAM-1.6-ext/tutorials/incompressible/icoFoam/cavity
nProcs : 1
SigFpe : Enabling floating point exception trapping (FOAM_SIGFPE).
Create time
Creating block mesh from
    "/home/maimouna/OpenFOAM/OpenFOAM-1.6-ext/tutorials/incompressible/icoFoam/cavity/constant/polyMesh/blockMeshDict"
Creating blockCorners
Creating curved edges
Creating blocks
Creating patches
Creating block mesh topology
Default patch type set to empty
Check block mesh topology
    Basic statistics
        Number of internal faces : 0
        Number of boundary faces : 6
        Number of defined boundary faces : 6
        Number of undefined boundary faces : 0
    Checking patch -> block consistency
Creating block offsets
Creating merge list .
Creating points with scale 0.1
Creating cells
Creating patches
Creating mesh from block mesh
Writing polyMesh
--> FOAM FATAL ERROR:
Failed writing polyMesh.
    From function blockMesh
    in file blockMeshApp.C at line 475.
FOAM exiting
maimouna@maimouna-desktop:~/OpenFOAM/OpenFOAM-1.6-ext/tutorials/incompressible/icoFoam/cavity$ ^Cmaimouna@maimouna-desktop:~/OpenFOAM/OpenFOAM-1.6-ext/tutorials/incompressible/icoFoam/cavity$
I couldn't understand that comments.
At the end, I tried blockMesh for cavity case but also the error shown there.
Please, help me to avoid that.
Many thanks for advanced.
Old   November 26, 2013, 15:36
Bruno Santos
Hi Maimouna,
It's looking good now! So the explanation is as follows:
  1. The long output given when you ran of16ext is normal!
    It shows all of the custom settings that were defined for OpenFOAM 1.6-ext shell environment.
  2. The reason why blockMesh is complaining is probably because the installation was made with the "root" account, also known as the super-user account.
    There are 2 ways to fix this:
    1. You can follow the standard tutorial instructions: http://www.openfoam.org/docs/user/tu...s.php#x4-30002
      mkdir -p $FOAM_RUN
      cp -r $FOAM_TUTORIALS $FOAM_RUN
      This way you work with a copy of the original tutorials, without damaging the original tutorials.
    2. Or you can re-assign the OpenFOAM folder to your own user name, by running the following commands:
      ls -l $HOME/OpenFOAM
      sudo chown -R $USER:$USER $HOME/OpenFOAM
      This should:
      1. The first one shows you the contents of the folder "~/OpenFOAM" and tell you that the owner of some of the folders is "root:root".
      2. The second command line will reassign the ownership of all files and folders within "~/OpenFOAM" to your user name.
      3. The third one shows you the contents of the folder "~/OpenFOAM" and should tell you that the owner of all of the folders is "maimouna:maimouna".
Best regards,
Bruno
Old   November 27, 2013, 06:39
ok
Dear Bruno,
my plenty of thanks to you. It works fine now.
I still have one problem with ParaView in of16ext.
I followed your post #3 which is given in
http://www.cfd-online.com/Forums/openfoam-installation/120327-can-different-openfoam-versions-share-same-paraview.html
but it gives me the following remark
maimouna@maimouna-desktop:~/OpenFOAM/maimouna-1.6-ext/run/tutorials/incompressible/icoFoam/cavity$ paraFoam -builtin
unknown option/argument: '-builtin -builtin'
usage: paraFoam [OPTION]
options:
-case dir specify alternative case directory
-region name specify mesh region name
-touch only create the .foam file
* start paraview with the OpenFOAM libraries
and I already add
alias paraFoam = 'paraFoam -builtin' in ~/.bashrc
Old   November 27, 2013, 17:45
Bruno Santos
Hi Maimouna,
Mmm... OK, try these steps:
  1. Start the terminal with the environment for OpenFOAM 1.6-ext:
    of16ext
  2. Go into the folder where the script paraFoam is located:
    cd $WM_PROJECT_DIR/bin
  3. Download the latest paraFoam script from 2.2.x:
    wget "https://raw.github.com/OpenFOAM/OpenFOAM-2.2.x/master/bin/paraFoam" -O paraFoam
    Note: this is assuming you followed the instructions from my previous post, for fixing the permissions in the OpenFOAM folder.
  4. Now you can go into the "cavity" tutorial case folder, run the case and then paraFoam:
    cd $FOAM_RUN/tutorials/incompressible/icoFoam/cavity
    blockMesh
    icoFoam
    paraFoam
Best regards,
Bruno
codder likes this.
Old   November 28, 2013, 05:34
ok
Dear Bruno,
sorry for disturbing you again.
I followed all steps that you give,but unfortunately, it was not working. It gives
/home/maimouna/OpenFOAM/OpenFOAM-1.6-ext/bin/paraFoam: 267: /home/maimouna/OpenFOAM/OpenFOAM-1.6-ext/bin/paraFoam: paraview: not found.
I already built it.
Whats wrong?
Old   November 28, 2013, 07:15
ok
Dear Bruno,
I tried it many times by following the previous post and this post. It still gave me the same error after paraFoam and I tried paraFoam -builtin as well, both give me the same
FATAL ERROR: ParaView reader module libraries do not exist
Please build the reader module before continuing:
cd $FOAM_UTILITIES/postProcessing/graphics/PV3Readers
./Allwclean
./Allwmake
Are there any special aliasis need in ~/.bashrc file?
Moreover, I didn't have $WM_PROJECT_DIR. Directly, I went to
/home/maimouna/OpenFOAM/OpenFOAM-1.6-ext/bin which has paraFoam script.
Did this affect steps?
Many thanks in advanced.
Old   November 29, 2013, 11:53
ok
Dear Bruno,
when I tried
paraFoam -builtin
it gives me
Can you help me please on that comment.
unable to install openfoam 1.7 using apt-get maazhmd OpenFOAM Installation 7 July 24, 2011 11:18
Cross-compiling OpenFOAM 1.6 on Linux for Windows 32 and 64bits with Mingw-w64 wyldckat OpenFOAM Announcements from Other Sources 7 January 19, 2010 15:39
OpenFOAM 1.6 installation in Ubuntu 9.1 jsm OpenFOAM Installation 4 January 3, 2010 22:53
List of glitches found on OpenFOAM 1.6 wyldckat OpenFOAM Bugs 5 November 17, 2009 07:51
Install of OpenFOAM 1.6 Error 1 Error 2 & run tutorial potac OpenFOAM Installation 3 August 27, 2009 09:04
