[foam-extend.org] foam-extend-3.0 installation
Like Tree6Likes
  • 2 Post By codder
  • 3 Post By wyldckat
  • 1 Post By sita
Old   December 21, 2013, 21:50
Default foam-extend-3.0 installation
Eric Bryant
codder is on a distinguished road
Dear Foamers -
I attempted to install foam-extend-3.0 according to the instructions on:
http://wikki.gridcore.se/foam-extend/download
My approach was to:
(1) Run inside ~/foam
export PARAVIEW_SYSTEM=1
(2) Then follow http://wikki.gridcore.se/foam-extend/download but without using
export QT_BIN_DIR=/path/to/qmake
... yet substituting:
./Allwmake.firstInstall >& log.make
Notes:
I have no other prior foam installations for this user. My .bashrc contains
source /home/eric/foam/foam-extend-3.0/etc/bashrc
I did not, for example, copy a etc/prefs.sh-EXAMPLE to etc/prefs.sh. Only the Wikki instructions were used.
(3) I then got "paraFoam -builtin" working by updating the script:
cd $WM_PROJECT_DIR/bin
wget "https://raw.github.com/OpenFOAM/OpenFOAM-2.2.x/master/bin/paraFoam" -O paraFoam
... as per this post.
Thank you so much Wikki and various contributors! Installing the extend code base was never so easy (at least for me) before.
karamiag and wyldckat like this.
Last edited by codder; January 15, 2014 at 18:57. Reason: Removed reference to old name of extend fork.
codder is offline   Reply With Quote
Old   December 26, 2013, 17:54
Default swak4foam
Eric Bryant
I believe compiling within ~/foam/foam-extend-3.0 directory breaks compatibility with version checks performed here:
ThirdParty/rpmBuild/BUILD/swak4Foam-0.2.4/Libraries/swak4FoamParsers/include/swak.H
... if you desire swak4Faom, it may be better to maintain ~/OpenFOAM/OpenFoam-1.6-ext and edit within etc/bashrc:
export WM_PROJECT=foam
export WM_FORK=extend
export WM_PROJECT_VERSION=3.0
<snip>
export WM_PROJECT_DIR=$WM_PROJECT_INST_DIR/$WM_PROJECT-$WM_FORK-$WM_PROJECT_VERSION
... although I have not tried this. As a newbie, I'm not sure what other code performs version checking.
Old   December 30, 2013, 17:01
Retired Super Moderator
Bruno Santos
Greetings Eric,
Many thanks for sharing your findings!
On this topic, I've finished setting up the first wiki pages at openfoamwiki.net for installing foam-extend-3.0: http://openfoamwiki.net/index.php/In...oam-extend-3.0
Most of the instructions are pointing to the official installation instructions, but I've done some tests of my own in building on Ubuntu 12.04, 12.10 and 13.10, which are all presently documented at: http://openfoamwiki.net/index.php/In...end-3.0/Ubuntu
Note: these instructions are considerably different from the ones presently located at http://wikki.gridcore.se/foam-extend/download - simply because I relied on the old way for 1.6-ext and because I didn't want to build with CUDA support.
Since foam-extend-3.0 is still rolling out, there are still some details that need fine tuning (which is also why I went with the old build strategy). One of them is the need to wait for the release of swak4Foam 0.3.0, as reported here: http://sourceforge.net/apps/mantisbt...iew.php?id=193
Best regards,
Bruno
AmirBaqa1987, fportela and codder like this.
Old   April 2, 2014, 17:27
Default foam-extend-3.0 on Centos 6.5
Tony Ladd
tladd is on a distinguished road
I have been experimenting with installing foam-extend-3.0 on Centos 6.5
It turns out to be quite straightforward since the installed compiler gcc 4.4.7 is sufficiently up to date. The official instructions for extend-1.6 on Centos 5.5 (foam-extend-3.0/doc/buildInstructions/Centos/5.5) are close to what is needed for foam-extend-3.0.
The listed system packages were all installed on my version of Centos but in addition you need to install binutils-devel:
(as root)
yum install binutils-devel
Otherwise the library file libiberty.a is missing which causes the compilation of openfoam to fail
In addition if you want an automatic installation of swak4foam you should also install mercurial:
yum install mercurial
Finally you need to make it install qt-4.8.5 by setting QT_THIRD_PARTY=1. My prefs.sh file (in foam-extend-3.0/etc) was:
export FOAM_VERBOSE=1 # Verbose for install
compilerInstall=System # Use System compiler
WM_MPLIB=OPENMPI # Use Third Party MPI
export QT_THIRD_PARTY=1 # Use Third Party QT
If you use the SYSTEMOPENMPI then you need to source the module environment as with the official OpenFOAM release:
module load openmpi-x86_64
Then just
./Allwmake.firstInstall > wmake.log 2>&1
At first I tried to use the third-party gcc (because I had not realized I needed binutils-devel) but this caused problems. I had a number of issues with the system compilers but I will file bug reports on these as soon as I get my sourceforge registration. But I could not get any of the versions of gcc to compile. I had to link other wmake rules in some cases and so I was not sure if this was correct (also the spec files for 4.6 do not match the AllMake.stage1), but even after this I would get errors because the system compiler could not find the gmp etc. libraries. I fixed this with LD_LIBRARY_PATH but there was a further problem at which point I gave up and went back to make the system compiler work.
Finally I could not get the doxygen to compile correctly - the first error is
18850 Preprocessing /global/usr/apps/FOAM/foam-extend-3.0/applica/global/usr/apps/FOAM/foam-extend-3.0/applications/solvers/multiphase/interPhaseChangeFoam/phaseChangeTwoPhaseMixtures/Merkle/Merkle.H:120: Warning: reached end of file while inside a verbatim block!
18851 The command that should end the block seems to be missing!
18852
18853 tions/solvers/multiphase/interPhaseChangeFoam/alphaEqn.H...
I think the error message fragmented the output line because I merged both streams into 1 file.
tladd is offline   Reply With Quote
Old   May 8, 2014, 05:30
xuhe-openfoam
bieshuxuhe is on a distinguished road
hi,
I did as Eric Bryant(foam-extend-3.0 installation) told us .
but i get
sxh@sxh-VirtualBox:~/foam/sxh-3.0/run/tutorials/incompressible/icoFoam/cavity$ paraFoam -builtin
created temporary 'cavity.foam'
/home/sxh/foam/foam-extend-3.0/bin/paraFoam: 267: /home/sxh/foam/foam-extend-3.0/bin/paraFoam: paraview: not found
could you help me ? what is wrong?
thanks
I am so sorry !
I have solve this problem by :
sudo apt-get install paraview
sorry again
Last edited by wyldckat; May 8, 2014 at 14:55. Reason: merged two posts, since they were posted a few minutes apart
bieshuxuhe is offline   Reply With Quote
Old   May 9, 2014, 00:35
Default follow this link instead
Eric Bryant
This thread is out-dated. It referred to installation before this wiki page was created:
Best, E
Old   May 19, 2014, 11:35
Tony Ladd
Eric
The wiki page is for Fedora 19. It is not necessarily the same in RHEL/CentOS 6, which is based on Fedora 12.
Tony
Old   May 7, 2019, 08:47
Sita Drost
sita is on a distinguished road
Sorry, I know that this thread is rather old, but I thought I'd add to it anyway: I just installed foam-extend-3.1 on Scientific Linux 7.3 using these instructions: https://idurun.com/2015/01/24/instal...1-on-centos-7/
I found those really useful, and as I didn't see this link on the OpenFOAM Wiki, I thought I'd post it here, perhaps it could be added.
Cheers,
Sita
wyldckat likes this.
sita is offline   Reply With Quote
Sig Density Based Solver installation with FOAM Extend 3.2 qjh888 OpenFOAM Bugs 0 September 21, 2016 08:16
[foam-extend.org] Foam extend (>3.0) on Windows using cygwin. Saideep OpenFOAM Installation 0 May 30, 2016 10:40
[mesh manipulation] Importing Multiple Meshes thomasnwalshiii OpenFOAM Meshing & Mesh Conversion 18 December 19, 2015 18:57
OpenFOAM on MinGW crosscompiler hosted on Linux allenzhao OpenFOAM Installation 127 January 30, 2009 19:08
