[OpenFOAM.org] OpenFoam installation on CentOs 6.5 without root access
Like Tree6Likes
Old   June 10, 2016, 03:19
Wang Wei
Wang Wei is on a distinguished road
Hi,Chariton, below is the commands I used in compiling openfoam v3.0.1 in my /home directory.
1. mkdir OpenFOAM
cd OpenFOAM
wget "http://downloads.sourceforge.net/foam/OpenFOAM-3.0.1.tgz?use_mirror=mesh" -O OpenFOAM-3.0.1.tgz
wget "http://downloads.sourceforge.net/foam/ThirdParty-3.0.1.tgz?use_mirror=mesh" -O ThirdParty-3.0.1.tgz
tar -xzf OpenFOAM-3.0.1.tgz
tar -xzf ThirdParty-3.0.1.tgz
2. module load openmpi/intel/1.10.2 || export PATH=$PATH:/usr/lib64/openmpi/bin
export LD_LIBRARY_PATH=/usr/lib64/openmpi/lib/:$LD_LIBRARY_PATH
3. source $HOME/OpenFOAM/OpenFOAM-3.0.1/etc/bashrc WM_LABEL_SIZE=64 foamCompiler=system
4. echo "alias of301='module load openmpi/intel/1.10.2; source \$HOME/OpenFOAM/OpenFOAM-3.0.1/etc/bashrc $FOAM_SETTINGS'" >> $HOME/.bashrc
5. module load gcc/4.9.3
6. cd $WM_PROJECT_DIR
./Allwmake -j 4 > log.make 2>&1
It works well, I can calculate my case using it, but there are fatal errors in log.make file like this
In file included from ../conformalVoronoiMesh/lnInclude/CGALTriangulation3Ddefs.H:41:0,
from ../conformalVoronoiMesh/lnInclude/conformalVoronoiMesh.H:46,
from foamyHexMesh.C:36:
../conformalVoronoiMesh/lnInclude/CGALTriangulation3DKernel.H:36:43: fatal error: CGAL/Delaunay_triangulation_3.h: No such file or directory
#include "CGAL/Delaunay_triangulation_3.h"
compilation terminated.
make[2]: *** [/home/nus/e0013038/OpenFOAM/OpenFOAM-3.0.1/platforms/linux64GccDPInt64Opt/applications/utilities/mesh/generation/foamyMesh/foamyHexMesh/foamyHexMesh.o] Error 1
make[1]: *** [generation] Error 2
make[1]: *** Waiting for unfinished jobs....
I don't know what's the purpose of CGAL.
Wang Wei is offline   Reply With Quote
Old   January 31, 2018, 05:08
Chayanit Nigaltia
CHAYANIT is on a distinguished road
Originally Posted by wyldckat View Post
Quick question: Have you tried following the instructions given here: http://openfoamwiki.net/index.php/In...HEL#CentOS_6.5
If not, then since you do not have root access, you can skip the first 3 steps.
And since you're trying to install on a cluster, you can also skip steps 16 to 18.
I also want to install openfoam in centOS with no root access and I also skiiped the first three steps. But the system shows the following error with .tar file.
[chayanit@un03 OpenFOAM]$ tar -xzf OpenFOAM-2.3.0.tgz
gzip: stdin: not in gzip format
tar: Child returned status 1
tar: Error is not recoverable: exiting now
CHAYANIT is offline   Reply With Quote
Old   December 10, 2018, 06:00
Ramana
svramana is on a distinguished road
Hi everyone, I'm also trying to install OF5.0 on my institute cluster in home folder. I also don't have root access. I have followed all the instruction given in this link, https://openfoam.org/download/5-0-source/. After running ./Allwake command I'm getting following error
In file included from UOPwrite.C:30:0:
PstreamGlobals.H:42:17: fatal error: mpi.h: No such file or directory
#include <mpi.h>
make: *** [/data/me16d023/OpenFOAM/OpenFOAM-5.0/platforms/linux64GccDPInt32OptSYSTEMOPENMPI/src/Pstream/mpi/UOPwrite.o] Error 1
Anybody have solution ? Please help me.
svramana is offline   Reply With Quote
Old   December 16, 2018, 15:18
Retired Super Moderator
Bruno Santos
Quick answer: The Institute cluster should have a way to load/activate the MPI version that could be used with OpenFOAM. My guess is that if you run the following command:
module avail
you should get a complete list of the available modules in that cluster. Among them, search for one that states "openmpi" in some way. Then you can load the respective version, by using the associated name, for example, the name "openmpi/1.10.1" would be activated by running this command:
module load openmpi/1.10.1
then try building OpenFOAM once again.
Old   December 21, 2018, 11:09
Ramana
Thank you sir. It work for me.
Old   September 11, 2019, 05:26
Fahime Firoozpour
Fahime is on a distinguished road
Originally Posted by elham usefi View Post
Hi I found the solution arsalan.dryi sent me the correct links
thanks
Hi Ebrahim
can you plz send me those links?
Thanks in advance
Fahime is offline   Reply With Quote
Old   July 1, 2020, 14:00
James
Madeinspace is on a distinguished road
Hi Bruno,
I followed your instructions to install OF3.0.1 on the cluster without root access given in this link.
https://openfoamwiki.net/index.php/I...CentOS_SL_RHEL
SInce the OS of my university cluster is CentOS Linux release 7.8.2003 (Core). I followed the post#3 i.e for CentOS 7.1
I skipped step 1, 2 and 3.
Step 4, 5, 6, 7 worked normally.
For step 8, I first loaded
module load GCC/9.3.0 OpenMPI/4.0.3
based on the available MPI on the cluster as below
$ module spider OpenMPI/4.0.3
OpenMPI: OpenMPI/4.0.3
Description:
The Open MPI Project is an open source MPI-3 implementation.
You will need to load all module(s) on any one of the lines below before the "OpenMPI/4.0.3" module is availabl
e to load.
GCC/9.3.0
Help:
Description
More information
- Homepage: https://www.open-mpi.org/
and executed
module load GCC/9.3.0 OpenMPI/4.0.3 || export PATH=$PATH:/usr/lib64/openmpi/bin
I also changed the alias in step 8 accordingly
echo "alias of301='module load GCC/9.3.0 OpenMPI/4.0.3; source \$HOME/OpenFOAM/OpenFOAM-3.0.1/etc/bashrc $FOAM_SETTINGS'" >> $HOME/.bashrc
Then I proceeded to compile further. I didn't have any error or warning. However. the final compilation with ./Allwmake failed.
The first error says
error: static assertion failed: "MPI_Type_extent was removed in MPI-3.0. Use MPI_Type_get_extent instead."
322 | #define THIS_SYMBOL_WAS_REMOVED_IN_MPI30(func, newfunc) _Static_assert(0, #func " was removed in MPI-3.0. Use " #newfunc " instead.")
I have no idea what this means but I suspect it is from the loading of OpenMPI.
Would you please have a look at the log file of the compilation I have attached. I would sincerely appreciate your help.
Best regards,
James
Madeinspace is offline   Reply With Quote
Old   March 6, 2021, 08:48
FBR
FBR
FBR is on a distinguished road
I need to install openfoam6 on a cluster without root access. Is there any useful website to guide me?
Thanks
FBR is offline   Reply With Quote
Old   March 6, 2021, 11:31
Mark Olesen
olesen has a spectacular aura aboutolesen has a spectacular aura about
Originally Posted by FBR View Post
Thanks
You generally don't need root access but will need development tools (gcc, make etc) and some basic development headers (eg for zlib).
Take a look at the wiki: https://develop.openfoam.com/Develop...wikis/building
Should be reasonably similar to what you need for the .org version.
olesen is offline   Reply With Quote
centos, installation of openfoam, root access
How to contribute to the community of OpenFOAM users and to the OpenFOAM technology wyldckat OpenFOAM 17 November 10, 2017 15:54
[OpenFOAM.org] OpenFOAM 2.4.x on CentOS 6.5 kpsl OpenFOAM Installation 2 July 27, 2015 06:50
[OpenFOAM.org] How to get OpenFoam compiled on a cluster with CentOS 6.5 and no root permissions hulli OpenFOAM Installation 2 November 6, 2014 18:01
OpenFOAM 1.5.x package - CentOS 5.3 x86_64 linnemann OpenFOAM Installation 7 July 30, 2009 03:14
OpenFOAM 15 and CentOS 52 installation issues remrich OpenFOAM Bugs 9 March 20, 2009 01:48
