No foam Mesh file were created
Old   July 21, 2008, 16:54
Default I've been installed the OpenFo
Paul
pajofego is on a distinguished road
I've been installed the OpenFoam package 1.5 on my ubuntu 8.04 system and I try to run the good cavity tutorial. After typing:
paraFoam -case $FOAM_RUN/tutorials/icoFoam/cavity
ParaView 3.3.0 starts and ask me to choose a reader for the cavity.openfoam. When I click on OpenFoam Files paraView crashes containing following message:
terminate called after throwing an instance of 'std::length_error'
what(): basic_string::_S_create
Aborted
When I go into my directory I cannot find any *.foam file which has to been created after typing - as described in the tutorial - blockMesh.
So annyone knows how to fix this problem?
Thanks in advance.
Best regards
pajofego
pajofego is offline   Reply With Quote
Old   July 21, 2008, 17:41
Default Hi Paul, have you tried to
Ville Tossavainen
villet is on a distinguished road
Hi Paul,
have you tried to compile ParaView 3.3.0 and PV3FoamReader? It worked for me. Read the OpenFOAM README file for the instructions.
There has been discussion about problems with Qt:
http://www.cfd-online.com/OpenFOAM_D...es/1/8314.html
Cheers,
Ville
villet is offline   Reply With Quote
Old   July 22, 2008, 17:34
Default Hi Ville, thanks for the ad
Paul
Hi Ville,
thanks for the advice! After compiling ParaView and PV3FoamReader the cavity example now works for me.
Thanks.
Paul
Mesh is created in blocking Severin CFX 3 September 18, 2007 09:02
[OpenFOAM] No foam file jhierroa ParaView 10 October 4, 2006 06:48
[OpenFOAM] ParaFoam outputs empty foam file theof ParaView 1 January 20, 2006 13:51
Post file is not created Julie Polyakh Siemens 8 January 12, 2004 14:28
Dead cells created on edges when a grid file is generated in GAMBIT and imported into FLUENT4 Isaac Manohar Ch. FLUENT 1 June 2, 2000 04:58
