compilation failed on OpenSuSE 12.1 x86_64
Like Tree2Likes
  • 1 Post By kpsl
  • 1 Post By alberto
Old   November 17, 2011, 21:01
Default compilation failed on OpenSuSE 12.1 x86_64
Pei-Ying Hsieh
phsieh2005 is on a distinguished road
Dear OpenFOAMers,
I am wondering if anyone encounters the problem I am experiencing and has a solution for it.
I received error on scotch and ptscotch. Part of the error below. It looks like this might be due to openmpi.
Pei
./dummysizes: error while loading shared libraries: libmpi.so.1: cannot open shared object file: No such file or directory
make[2]: *** [scotch.h] Error 127
make[2]: *** Waiting for unfinished jobs....
make[2]: Leaving directory `/home/phsieh/OpenFOAM/ThirdParty-2.0.x/scotch_5.1.11/src/libscotch'
make[1]: *** [ptscotch] Error 2
make[1]: Leaving directory `/home/phsieh/OpenFOAM/ThirdParty-2.0.x/scotch_5.1.11/src/libscotch'
make: *** [ptscotch] Error 2
phsieh2005 is offline   Reply With Quote
Old   November 18, 2011, 03:43
Kris
kpsl is on a distinguished road
I solved this by opening up OpenFOAM-2.0.x/etc/bashrc and changing two entries:
Set gcc to gcc46:
#- Compiler:
# WM_COMPILER = Gcc | Gcc43 | Gcc44 | Gcc45 | Gcc46 | Clang | Icc (Intel icc)
export WM_COMPILER=Gcc46
and use systemopenmpi:
#- MPI implementation:
# WM_MPLIB = SYSTEMOPENMPI | OPENMPI | MPICH | MPICH-GM | HPMPI
# | GAMMA | MPI | QSMPI
export WM_MPLIB=SYSTEMOPENMPI
Note that you should install openmpi-devel for this to work:
sudo zypper install openmpi openmpi-devel
After that OpenFOAM should compile without problems.
Hope this helps.
anon_a likes this.
kpsl is offline   Reply With Quote
Old   November 18, 2011, 04:56
Pei-Ying Hsieh
Hi, kpsl,
Thanks a lot! Your steps solved this issue.
By the way, did you also try compiling paraview? ./makeParaView also failed to compile on OpenSuSE 12.1. I am using the binary version that I downloaded from paraview.org. But, will be nice to know how to resolve the ./makeParaView problem too.
Pei
Old   November 18, 2011, 06:42
Kris
edit the file
ParaView-3.10.1/VTK/Utilities/vtkmetaio/metaUtils.cxx
and include the line:
#include <stddef.h>
Afterwards paraview will compile without any problems.
Good luck!
Old   November 18, 2011, 12:25
Alberto Passalacqua
For paraview, upgrading to paraview-3.12.0 does the job too. See http://albertopassalacqua.com/?p=1080 for a quick guide.
kpsl likes this.
Alberto Passalacqua
Old   November 18, 2011, 12:58
Thumbs up
Pei-Ying Hsieh
Thanks Kris,
Paraview-3.10 compiled successfully now.
Also, Thanks Alberto! I will give Paraview-3.12 a try.
Pei
Old   November 30, 2011, 06:58
Birkov is on a distinguished road
Hi to all,
I have same problem. I made recommended changes but still same result.
Here is part of my log
./dummysizes library.h scotch.h
./dummysizes: error while loading shared libraries: libmpi.so.0: cannot open shared object file: No such file or directory
make[2]: Leaving directory `/home/birkov/OpenFOAM/ThirdParty-2.0.x/scotch_5.1.11/src/libscotch'
make[1]: Leaving directory `/home/birkov/OpenFOAM/ThirdParty-2.0.x/scotch_5.1.11/src/libscotch'
+ make realclean
I have tried reinstall openmpi and openmpi-devel.
I went through step by step this tutorial http://albertopassalacqua.com/?p=1080.
When I tried this tutorial on virtual system everything was good.
Thank you for your advice.
B.
Birkov is offline   Reply With Quote
Old   November 30, 2011, 14:15
Alberto Passalacqua
What does (run it using the same user who launches OpenFOAM)
mpi-selector --list
say?
Alberto Passalacqua
Old   November 30, 2011, 14:46
say the same thing as in your tutorial.
openmpi-1.4.3
Thank you! (for your response but I did everything by your tutorial and for me there is no way how to solve this problem)
Old   December 6, 2011, 07:13
Retired Super Moderator
Bruno Santos
Greetings to all!
@Birkov: I don't know if you managed to solve your problem and I completely forgot to reply to you after I read your posts a few days ago. I came across a problem back in July which seems to be the same one as yours:
Originally Posted by http://albertopassalacqua.com/?p=973#div-comment-15403
The following post should contain some information that might be useful to all: http://www.cfd-online.com/Forums/ope...tml#post317607 - Post #56
To sum up:
* it’s easier to use “mpi-selector-menu”, since it’s more interactive
* it’s necessary to logout and log back in for the selection to take effect.
* the package “openmpi-devel” is also necessary.
It should be as simple as logging out and logging back in.
Best regards,
Bruno
Old   December 6, 2011, 09:38
Thank you for your comment wyldckat.
I still have the problem and I tried almost everything that I found (not "everything") but still same error.
I'll try do some test in my virtual system (I'll install OpenFOAM on my work computer too so maybe here I'll find the reason "why")
Anyway thank you.
B.
Transient boundary conditions Jarrod Sinclair (Sinclair) OpenFOAM Running, Solving & CFD 133 May 6, 2015 06:21
DeardorffDiffStress turbulence model Zuixy OpenFOAM Running, Solving & CFD 0 November 14, 2011 08:44
[OpenFOAM] ParaView/Parafoam error when making animation Disco_Caine ParaView 6 September 28, 2010 09:54
user subroutine error CFDUSER CFX 2 December 9, 2006 06:31
user defined function cfduser CFX 0 April 29, 2006 10:58
