How can i set the enviroment for the openfoam
Old   July 8, 2005, 06:08
Default i have upack the openfoam ,but
ztdep's Avatar
p ding
ztdep is on a distinguished road
Send a message via Yahoo to ztdep Send a message via Skype™ to ztdep
i have upack the openfoam ,but i can not pass the foamInstallationcheck ,how can i set those path ,and .bashrc file .where can i find it .
my root is /fortran .
thank you very much
ztdep is offline   Reply With Quote
Old   July 8, 2005, 06:23
Default To properly install OpenFOAM d
Alberto Passalacqua
To properly install OpenFOAM do as follows:
Create a directory called OpenFOAM in your home and copy the OpenFOAM-1.1 directory into it.
Install Java, gcc and paraview in /OpenFOAM/linux (if you're using linux).
Add this line to your /home/.bashrc file:
. $HOME/OpenFOAM/OpenFOAM-1.1/.OpenFOAM-1.1/bashrc
Create your user directory as explained in the README file.
Regards,
Alberto
Alberto Passalacqua
Old   July 8, 2005, 10:12
Default but i do not know how to creat
ztdep's Avatar
p ding
but i do not know how to create my directory.
thank you for your regards
Old   July 8, 2005, 11:06
Default From the README file: Creat
Alberto Passalacqua
Create a project directory within the $HOME/OpenFOAM directory named
<username>-1.1 (e.g. 'chris-1.1' for user chris) and create a
directory named 'run' within it, e.g. by typing:
mkdir -p $HOME/OpenFOAM/${LOGNAME}-1.1/run
Copy the 'tutorial' examples directory in the OpenFOAM distribution to the
'run' directory. If OpenFOAM environment variables are set correctly, then
the following command will be correct:
cp -r $WM_PROJECT_DIR/tutorials $HOME/OpenFOAM/${LOGNAME}-1.1/run
Run the first example case of incompressible laminar flow in a cavity:
cd $HOME/OpenFOAM/${LOGNAME}-1.1/run/tutorials/icoFoam
blockMesh . cavity
icoFoam . cavity
Regards,
Alberto
Alberto Passalacqua
OpenFoam vs CFX5 mass balance in OpenFoam tangd OpenFOAM Running, Solving & CFD 33 May 23, 2010 16:36
[blockMesh] CheckMesh error using a tutorial from OpenFOAM 114 with openFOAM 13 martapajon OpenFOAM Meshing & Mesh Conversion 7 January 21, 2008 12:52
OpenFOAM users in Munich OpenFOAM benutzer in M%c3%bcnchen jaswi OpenFOAM 0 August 3, 2007 13:11
A new Howto on the OpenFOAM Wiki Compiling OpenFOAM under Unix mbeaudoin OpenFOAM Installation 2 April 28, 2006 08:54
how to set DISPLAY enviroment variable peter FLUENT 8 March 4, 2003 19:49
