FoamX Case Browser
Old   March 27, 2008, 14:46
Default when I start FoamX the Case Br
Theo
holgerbre is on a distinguished road
when I start FoamX the Case Browser window is completely empty and I cannot start the tutorials.
As suggested in the documentation, I have copied the tutorials to $FOAM_RUN and the OpenFOAM/OpenFOAM-1.4.1/.OpenFOAM-1.4.1/controlDict are all set to $FOAM_RUN/tutorials/...
what could be the problem ?
Thank you,
Holger
holgerbre is offline   Reply With Quote
Old   April 1, 2008, 03:13
Default Hi Holger, Iam have the sam
Mark Couwenberg
markc is on a distinguished road
Hi Holger,
Iam have the same, but more strangely: I used to run FoamX perfectly. But now, after running some calculation, I can not contact the case browser anymore.
Any help?
Brgds,
Mark
markc is offline   Reply With Quote
Old   April 1, 2008, 04:20
Default I found the problems: 1. I pu
Mark Couwenberg
1. I put some small document with project information in the $FOAM_RUN directory, which causes the casebrowser to not connect.
2.
In the controldict file (/home/.../OF/OF-version) the marks <> were entered. Do not ask me who put them there...
Mark
Old   March 24, 2009, 13:02
Default error opening casebrowser
leo paul
leopaul is on a distinguished road
hi,
i had done some calculation like mark has said above and later when i tried opening the casebrowser it showed an error message sayin "casebrowser not found".i tried searching for the controldict file tht mark has mentioned but didnt find it..can someone tell me where to find it?its not in of/of-1.4/..or how to solve this prob..and also what causes this kind of thing?
thanks.
Leo
leopaul is offline   Reply With Quote
Old   March 30, 2009, 04:19
Mark Olesen
olesen has a spectacular aura aboutolesen has a spectacular aura about
The short answer is to stop using FoamX and start using the command-line and your favourite editor. FoamX has been the source of numerous irritations in the past and as of OpenFOAM-1.5 has been dropped completely.
olesen is offline   Reply With Quote
FoamX Create new case jam OpenFOAM Running, Solving & CFD 1 January 17, 2008 12:10
Problem seeing new case in case browser alan_fergus OpenFOAM Pre-Processing 9 June 22, 2006 03:46
FoamX Host Browser problem trevors OpenFOAM Pre-Processing 2 June 13, 2006 07:42
[Commercial meshers] How to modify a fluent case on FoamX joegi OpenFOAM Meshing & Mesh Conversion 2 June 7, 2006 08:28
FoamX error aachenBomb case Ervin Adorean (Adorean) OpenFOAM Pre-Processing 13 March 7, 2005 03:50
