Difficulties using parafoam, one critical error in installation of OpenFOAM-1.6
Old   March 30, 2010, 12:13
Default One critical error in installation of OpenFOAM-1.6
Peter Naamansen
PeterNaa is on a distinguished road
Dear all
I have a question regarding my installation of
OpenFOAM-1.6. My question has to do with my one critical error and the no's I get when I run the foamInstallationTest:
Executing /home/peter/OpenFOAM/OpenFOAM-1.6/bin/foamInstallationTest:
Checking basic setup...
Shell: bash
Host: peter-desktop
OS: Linux version 2.6.28-11-generic
Checking main OpenFOAM env variables...
Environment_variable Set_to_file_or_directory Valid Crit
$WM_PROJECT_INST_DIR /home/peter/OpenFOAM yes yes
$WM_PROJECT_USER_DIR /home/peter/OpenFOAM/peter-1.6 yes no
$WM_THIRD_PARTY_DIR /home/peter/OpenFOAM/ThirdParty-1.6 yes yes
Checking the OpenFOAM env variables set on the PATH...
Environment_variable Set_to_file_or_directory Valid Path Crit
$WM_PROJECT_DIR /home/peter/OpenFOAM/OpenFOAM-1.6 yes yes yes
$FOAM_APPBIN ...1.6/applications/bin/linux64GccDPOpt yes yes yes
$FOAM_SITE_APPBIN ...penFOAM/site/1.6/bin/linux64GccDPOpt no no
$FOAM_USER_APPBIN ...1.6/applications/bin/linux64GccDPOpt no no
$WM_DIR /home/peter/OpenFOAM/OpenFOAM-1.6/wmake yes yes yes
Checking the OpenFOAM env variables set on the LD_LIBRARY_PATH...
$FOAM_LIBBIN ...OAM/OpenFOAM-1.6/lib/linux64GccDPOpt yes yes yes
$FOAM_SITE_LIBBIN ...penFOAM/site/1.6/lib/linux64GccDPOpt no no
$FOAM_USER_LIBBIN ...enFOAM/peter-1.6/lib/linux64GccDPOpt no no
$MPI_ARCH_PATH ...nmpi-1.3.3/platforms/linux64GccDPOpt yes yes yes
Third party software
Software Version Location
gcc 4.3.3
WARNING: Conflicting installations:
OpenFOAM settings : /bin/gcc
current path : /usr/bin/gcc
CRITICAL ERROR
gzip 1.3.12 /bin/gzip
tar 1.20 /bin/tar
icoFoam 1.6 .../OpenFOAM-1.6/applications/bin/linux64GccDPOpt/icoFoam
Summary
Base configuration ok.
The foam installation contains 1 critical error(s).
Review the output for warning messages and consult
the installation guide for trouble shooting.
done.
I hope someone can help me with that. I am new to linux so
it will be difficult for me to understand an answer which is
too brief or too sophisticated.
Regards Peter
PeterNaa is offline   Reply With Quote
Old   April 6, 2010, 13:04
Retired Super Moderator
Bruno Santos
Greetings Peter,
I just sent you a reply to the pm you sent me. As for this thread, what has changed since your post? By the message you sent me, I think you've reinstalled OpenFOAM-1.6. If so, what instructions did you follow this time and does it all work now?
Best regards,
Bruno
Old   April 7, 2010, 06:45
Default Error writing polyMesh in line 346 of blockMeshApp.C, OF-1.6, Ubuntu 9.04
Peter Naamansen
Dear Bruno
You are correct, that I reinstalled OpenFOAM-1.6 (running Ubuntu 9.04).
In doing so, I was suddenly not able to run blockMesh. From your mail you indicated that it had to do with privilliges and the sodu command in
Ubuntu 9.04. Your solution, which proved correct, was to execute:
sudo chown -R username:username \home\username\OpenFOAM
Regards Peter
Old   April 9, 2010, 03:25
Default Critical error message in foamInstallationTest, OF-1.6
Peter Naamansen
Dear all
The problem with critical error messages
after executing foamInstallationTest could
in my case (now for a 32 bit system) be
solved by setting
WM_ARCH_OPTION = 32
in the file OpenFOAM\OpenFOAM-1.6\etc\bashrc
(remember saving and resourcing)
Peter
Old   April 9, 2010, 08:48
Bruno Santos
Hello Peter,
Thanks for the post, because I had completely forgotten to fix that yesterday Now at the post #335 of the install cookbook for Ubuntu you now have the fixed versions, with the addition of multi-core detection, thus making OpenFOAM built as fast as many cores the machines have available
Best regards,
Bruno
PS: as you suggested yesterday, I've made a rough document of helpful threads for building OpenFOAM... see my signature
installing openfoam 1.6, openfoam-1.6, parafoam, region status issues
CRITICAL ERROR on installation OpenFOAM 141 nuovodna OpenFOAM Installation 19 March 22, 2010 22:36
Critical errors during OpenFoam installation in OpenSuse 11.0 amscosta OpenFOAM 5 May 1, 2009 14:06
Critical errors gcc and icoFoam during installation of 15 quartzian OpenFOAM Installation 3 December 12, 2008 12:42
64bitrhel5 OF installation instructions mirko OpenFOAM Installation 2 August 12, 2008 18:07
Adventure of fisrst openfoam installation on Ubuntu 710 jussi OpenFOAM Installation 0 April 24, 2008 14:25
