Are OSIG TurboMachinery libraries able to work under OpenFOAM-1.6-ext?
Like Tree2Likes
Old   March 2, 2011, 04:25
linnemann's Avatar
Niels Nielsen
linnemann will become famous soon enough
1.6 ext versions of transientSimpleDyMFoam and turboPerformance library.
Linnemann
PS. I do not do personal support, so please post in the forums.
linnemann is offline   Reply With Quote
Old   August 30, 2012, 06:05
BigPapi34 is on a distinguished road
Hi there,
Quick question really - is turboPerformance something that will work with OpenFoam 2.1.x?
Any info would be great.
Cheers
BigPapi34 is offline   Reply With Quote
Old   August 30, 2012, 06:30
Håkan Nilsson
hani is on a distinguished road
turboPerformance has been merged with 2.0.x, and I guess that it should be possible to use that merge also with 2.1.x, or at least with minor modifications. I didn't test though.
See:
http://openfoam-extend.svn.sourcefor...boPerformance/
Håkan
hani is offline   Reply With Quote
Old   August 30, 2012, 07:02
Just downloaded and compiled this version in 2.1.x - works brilliantly! Exactly what I'm looking for and makes things neater.
Many thanks for the link.
Old   May 9, 2013, 20:54
任芸
renyun0511 is on a distinguished road
Because the website posted by Hani cannot be linked now. If you upload the turboPerformance on version-2.1.0 to share, I will appreciate it !
Thanks,
Yun Ren
renyun0511 is offline   Reply With Quote
Old   May 17, 2014, 02:25
Default turboPerformance for openfoam 2.3.0
  #26
Mohammed Ameenuddin
ameen@cfd is on a distinguished road
Hello everyone,
I am trying to use Sig turbomachinery library turbo performance for OpenFOAM 2.3.0, but when I compile the libraries of 2.0 as given in link below I get many errors. Are there any such libraries that I can use for OpenFOAM 2.3.0.
http://openfoamwiki.net/index.php/Sig_Turbomachinery_Library_turboPerformance#Downlo ad_and_compile
The errors are
SOURCE=forces/forces.C ;  g++ -m64 -Dlinux64 -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3  -DNoRepository -ftemplate-depth-100 -I/opt/openfoam230/src/finiteVolume/lnInclude -I/opt/openfoam230/src/meshTools/lnInclude -I/opt/openfoam230/src/sampling/lnInclude -I/opt/openfoam230/src/transportModels -I/opt/openfoam230/src/turbulenceModels -I/opt/openfoam230/src/turbulenceModels/LES/LESdeltas/lnInclude -I/opt/openfoam230/src/thermophysicalModels/basic/lnInclude -IlnInclude -I. -I/opt/openfoam230/src/OpenFOAM/lnInclude -I/opt/openfoam230/src/OSspecific/POSIX/lnInclude   -fPIC -c $SOURCE -o Make/linux64GccDPOpt/forces.o
forces/forces.C: In member function ‘Foam::tmp<Foam::GeometricField<Foam::SymmTensor<double>, Foam::fvPatchField, Foam::volMesh> > Foam::forces::devRhoReff() const’:
forces/forces.C:77:28: error: ‘const class Foam::incompressible::LESModel’ has no member named ‘devBeff’
forces/forces.C:86:24: error: ‘const class Foam::basicThermo’ has no member named ‘mu’
In file included from /opt/openfoam230/src/OpenFOAM/lnInclude/objectRegistry.H:242:0,
                 from /opt/openfoam230/src/OpenFOAM/lnInclude/Time.H:42,
                 from /opt/openfoam230/src/OpenFOAM/lnInclude/GeometricField.C:27,
                 from /opt/openfoam230/src/OpenFOAM/lnInclude/GeometricField.H:601,
                 from /opt/openfoam230/src/OpenFOAM/lnInclude/GeometricScalarField.H:38,
                 from /opt/openfoam230/src/OpenFOAM/lnInclude/GeometricFields.H:34,
                 from /opt/openfoam230/src/finiteVolume/lnInclude/volFields.H:37,
                 from forces/forces.C:28:
/opt/openfoam230/src/OpenFOAM/lnInclude/objectRegistryTemplates.C: In member function ‘const Type& Foam::objectRegistry::lookupObject(const Foam::word&) const [with Type = Foam::singlePhaseTransportModel]’:
forces/forces.C:95:35:   instantiated from here
/opt/openfoam230/src/OpenFOAM/lnInclude/objectRegistryTemplates.C:178:9: error: reference to ‘Foam::singlePhaseTransportModel::typeName’ is ambiguous
/opt/openfoam230/src/transportModels/incompressible/transportModel/transportModel.H:66:5: error: candidates are: const Foam::word Foam::transportModel::typeName
/opt/openfoam230/src/OpenFOAM/lnInclude/IOdictionary.H:72:5: error:                 const Foam::word Foam::IOdictionary::typeName
/opt/openfoam230/src/OpenFOAM/lnInclude/objectRegistryTemplates.C:195:9: error: reference to ‘Foam::singlePhaseTransportModel::typeName’ is ambiguous
forces/forces.C:120:1: warning: control reaches end of non-void function [-Wreturn-type]
make: *** [Make/linux64GccDPOpt/forces.o] Error 1
Thank you.
ameen@cfd is offline   Reply With Quote
Old   June 8, 2014, 15:22
Retired Super Moderator
Bruno Santos
Greetings to all!
I've given this a try and have adapted the "turboPerformance" library to OpenFOAM 2.1.x, 2.2.x and 2.3.x, based on the source code meant for OpenFOAM 2.0.x. It is now available here: https://github.com/wyldckat/OSIG-Tur...formance-OF2.x - I've also added a link for this repository at the wiki page, in the new section "Forks": http://openfoamwiki.net/index.php/Si...formance#Forks
I have only taken care of making the necessary changes to the library source code, for it to build with each OpenFOAM version. I have not tested if it's working as intended on all versions.
Therefore, if anyone has the time and resources, please test this first with OpenFOAM 2.0.x and then with the version of OpenFOAM you need to use, in order to confirm if everything is working as intended!
Best regards,
Bruno
linnemann and ameen@cfd like this.
1.5-dev, 1.6-ext, osig, turbomachinery
kOmegaSST in openfoam 1.6 Gearb0x OpenFOAM 2 March 3, 2010 06:02
Openfoam 1.6 ar_mofidi OpenFOAM 1 November 4, 2009 05:26
Adventure of fisrst openfoam installation on Ubuntu 710 jussi OpenFOAM Installation 0 April 24, 2008 14:25
Turbomachinery at OpenFOAM Workshop Milan 2008 hani OpenFOAM 0 March 21, 2008 02:33
OpenFOAM Debian packaging current status problems and TODOs oseen OpenFOAM Installation 9 August 26, 2007 13:50
