[OpenFOAM.com] Multiple Installation Issue: Parallel Processing No Longer Works |
June 27, 2011, 21:33 |
Daniel
Hello all,
I have been using OF1.7.x for a number of cases, and when OF2 was released I eagerly installed it. Unfortunately, since I installed OF2, I can no longer run applications in parallel in OF1.7.x. Some more info: -Parallel processing works fine in OF2 -There appears to be some kind of MPI problem (MPI installed with OF2 is newer than that installed with OF17x, did it delete the older version?) -I have set up my .bashrc to call one of the two OF bashrc when I call the appropriate alias -using Ubuntu 10.04 -I would like to continue using OF1.7.x for the cases that are in progress since it would take some effort to change the structure to be suitable for use in OF2. -I get the following error: Code:
-------------------------------------------------------------------------- Sorry! You were supposed to get help about: opal_init:startup:internal-failure But I couldn't open the help file: /home/dan/OpenFOAM/ThirdParty-1.7.x/platforms/linux64Gcc/openmpi-1.4.1/share/openmpi/help-opal-runtime.txt: No such file or directory. Sorry! -------------------------------------------------------------------------- [two-desktop:12987] [[INVALID],INVALID] ORTE_ERROR_LOG: Not found in file ../../../orte/runtime/orte_init.c at line 77 [two-desktop:12987] [[INVALID],INVALID] ORTE_ERROR_LOG: Not found in file ../../../../../orte/tools/orterun/orterun.c at line 541 Code:
------------------------------------------------------------------------------- Environment_variable Set_to_file_or_directory Valid Path Crit ------------------------------------------------------------------------------- $FOAM_LIBBIN ...M/OpenFOAM-1.7.x/lib/linux64GccDPOpt yes yes yes $FOAM_SITE_LIBBIN ...nFOAM/site/1.7.x/lib/linux64GccDPOpt no no $FOAM_USER_LIBBIN ...enFOAM/dan-1.7.0/lib/linux64GccDPOpt yes yes no $MPI_ARCH_PATH ...x/platforms/linux64Gcc/openmpi-1.4.1 no yes ------------------------------------------------------------------------------- Thanks, Dan |
Doubt about parallel processing | vishwesh | OpenFOAM Programming & Development | 0 | November 10, 2017 06:20 |
SU2v4.0.0 parallel installation error | Mohit Singh | SU2 Installation | 2 | February 19, 2016 13:17 |
Parallel Processing by region | Swift | OpenFOAM Running, Solving & CFD | 0 | July 30, 2015 08:42 |
Issue with running in parallel on multiple nodes | daveatstyacht | OpenFOAM | 7 | August 31, 2010 17:16 |
bubbly flow and parallel processing | mvee | FLUENT | 0 | September 12, 2007 05:08 |
