ThirdParty2.1.1 on Ubuntu 12.10 64bit
Old   October 24, 2012, 09:28
Talking ThirdParty2.1.1 on Ubuntu 12.10 64bit [solved]
Davide Cagnoni
davide_c is on a distinguished road
Hi everybody
I'm trying to install OpenFoam from source in my newly installed (from a formatted system) Ubuntu.
I followed the instructions from http://www.openfoam.org/download/source.php step by step, and the OpenFoam part seems to work ok, while the Paraview compilation seems to finish not successfully. Also, the PV3FoamReader module fails.
Here's an excerpt of how the makeParaview script output terminates:
[ 81%] Built target QtTesting
[ 81%] Built target TestingDemo
[ 83%] Built target pqWidgets
[ 83%] Building CXX object Qt/Core/CMakeFiles/pqCore.dir/pqAnimationScene.cxx.o
In file included from /home/davide/OpenFOAM/ThirdParty-2.1.1/ParaView-3.12.0/Qt/Core/pqAnimationScene.cxx:57:0:
/home/davide/OpenFOAM/ThirdParty-2.1.1/ParaView-3.12.0/Qt/Core/pqServerManagerSelectionModel.h:75:30: error: calls to overloaded operators cannot appear in a constant-expression
make[2]: *** [Qt/Core/CMakeFiles/pqCore.dir/pqAnimationScene.cxx.o] Error 1
make[1]: *** [Qt/Core/CMakeFiles/pqCore.dir/all] Error 2
make: *** [all] Error 2
Installation complete for paraview-3.12.0
Set environment variables:
export ParaView_DIR=/home/davide/OpenFOAM/ThirdParty-2.1.1/platforms/linux64Gcc/paraview-3.12.0
export PATH=$ParaView_DIR/bin:$PATH
export PV_PLUGIN_PATH=$FOAM_LIBBIN/paraview-3.12
Done
At first I thought everything was ok as the "Installation complete" line suggested, but then while trying to build the PV3blockMeshReader and the PV3FoamReader plugins, I had the following result:
+ [ -d /home/davide/OpenFOAM/ThirdParty-2.1.1/platforms/linux64Gcc/paraview-3.12.0 -a -r /home/davide/OpenFOAM/ThirdParty-2.1.1/platforms/linux64Gcc/paraview-3.12.0 ]
which I honestly cannot interpret.
Again, when I try to run the usual blockmesh-icofoam-parafoam sequence, the first two run smoothly while parafoam gives the following error:
FATAL ERROR: ParaView reader module libraries do not exist
Please build the reader module before continuing:
cd $FOAM_UTILITIES/postProcessing/graphics/PV3Readers
./Allwclean
./Allwmake
I tried to find out something on other topics but wasn't able to find any solution... can anybody help ?
Thank you a lot in advance,
davide
P.S.
i'm using the following versions of software:
gcc (Ubuntu/Linaro 4.7.2-2ubuntu1) 4.7.2
cmake version 2.8.9
QMake version 2.01a
Using Qt version 4.8.3 in /usr/lib/x86_64-linux-gnu
davide_c is offline   Reply With Quote
Old   October 24, 2012, 10:16
treima is on a distinguished road
why do you build OpenFoam from source and donīt you install the Deb Pack?
treima is offline   Reply With Quote
Old   October 24, 2012, 10:51
Davide Cagnoni
there's still no build for quantal... I can try later with the precise .deb (installing other stuff right now )
Old   October 24, 2012, 14:38
Retired Super Moderator
Bruno Santos
Greetings to all!
I've written instructions for both modes some weeks ago : http://openfoamwiki.net/index.php/In...u#Ubuntu_12.10
Best regards,
Bruno
Old   October 24, 2012, 17:38
Davide Cagnoni
Originally Posted by wyldckat View Post
Greetings to all!
Best regards,
Bruno
Thanks Bruno, I did not see your post from weeks ago... for the sake of curiosity, is the stuff you change in pqServerManagerSelectionModel.h an error/bug correction or just something which is supposed to be done?
I'll try out asap
P.S.
worked out perfectly thanks a lot !
Old   October 25, 2012, 02:45
Bruno Santos
Hi Davide,
I'm glad it worked.
For the lack of a better word: it's a hack. The modification is necessary because Gcc 4.7 is a lot more picky about the source code, demanding better coding standards
Best regards,
Bruno
Installing OpenFOAM 2.1.1 and ParaView 3.12.0 on Ubuntu 12.10 wyldckat OpenFOAM Installation 14 February 12, 2013 04:43
Ansys 12.0 on Ubuntu 10.10 64bit Krischan ANSYS 1 April 26, 2011 04:44
Installing OpenFOAM 1.7.0 on Ubuntu Hardy 64bit nuovodna OpenFOAM 2 July 1, 2010 09:24
OF 1.6 | Ubuntu 9.10 (64bit) | GLIBCXX_3.4.11 not found piprus OpenFOAM Installation 22 February 25, 2010 13:43
ubuntu 9.10 64bit - wmake missing headers soeren87 OpenFOAM Installation 5 November 11, 2009 10:01
